motor mounts 302/351w same? - Ford Truck Enthusiasts Forums
Old 09-20-2005, 09:53 PM
FordCrazy1970 FordCrazy1970 is offline
FordCrazy1970 is starting off with a positive reputation.
Smile motor mounts 302/351w same?
Is there a differance in motor mount location and type of motor mount you would on a 302 verses 351w? Installing a 302 and replacing a 351w I know alot of parts interchange but do they use the same motor mounts in the same location?
Old 09-20-2005, 11:13 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Yes, the same motor mount holes in the block.
Old 09-21-2005, 03:26 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
so your taking the 302 out for a 351w?
yes the mounts are identical
Old 09-21-2005, 06:36 PM
thanks! Do they bolt to the same location on the crossmember bracket?
Old 09-21-2005, 06:42 PM
TigerDan's Avatar
TigerDan TigerDan is offline
TigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputationTigerDan has a superb reputation
Yes, there's no difference. A 351W will bolt straight in where a 302 came out of. About the only problem you might encounter would be on the exhaust sytem. The 351W Has about an inch more deck height which will raise your manifolds or headers a little higher in the chassis, and further apart. Usually there is enough play in the exhaust sytem to adjust for the difference.
83 351W verse 93 efi 351W Austin Climer Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 02-22-2017 10:17 AM
Front accessories mounting NCTyphoonKid 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-11-2016 07:53 PM
351w to 351c jtjohn302 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-01-2013 09:39 PM
302 motor mounts Bender99 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-22-2010 06:06 AM
engine swap BroncoRoadKill 1978 - 1996 Big Bronco 2 03-17-2003 06:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
