97 Alternator??
97 Alternator??
Hello, battery light started to flicker and battery needle jumped up and down while traveling. Stopped at a gas station because needle dropped and head lights started to dim. When I stopped the needle jumped back to the regular position. Advance Auto tested battery and alternator. Alternator tested fine but battery was low. Purchased a new battery and the light would slightly flicker then remain on. Purchased another battery to make it home. Someone told me to unhook my battery post while the truck was still running. If the truck didnt kill that meant the alternator was good. The truck did not kill and battery light is still on without the flicker. I have two large lines that look like battery post that's mounted to the wall. I was told they are fuses but I dont know how to check it. I have no idea where the alternator fuse might be because the owners manual doesnt tell me much.
Thank you all for your help. I replaced the alternator and the battery light turned off. Truck ran fine for a while then the truck started running rough. Blue gray smoke started coming from the tail pipe. The thing that tell you how many miles to empty went crazy. Random miles to empty were showing. Noticed gas leaking from under the hood on the ground. Took it to a mechanic and was told my engine computer was spiked. Replaced computer and problem remained. I was told my alarm system was wired to my second fuel injector causing the injector to short. Cut alarm wire to second injector and problem went away. Now I have to go back to the installer who installed the alarm and have them wire it correctly. When it rain it pours.
Ismael Rivas
Modular V10 (6.8l)
01-03-2017 04:43 PM
shore
1997 - 2003 F150
04-17-2016 12:23 AM
Damifiknow
08-14-2015 03:50 PM
