EGR insufficient flow code showing - Ford Truck Enthusiasts Forums
Old 09-20-2005, 09:15 AM
davenpt davenpt is offline
davenpt is starting off with a positive reputation.
I am sorry I posted in a wrong format. I am new and am not familiar with all this yet.
I have a 2002 F-150 that is showing a code indicating "EGR insufficient flow". I replaced the EGR valve and cleared the light/code, but the "check engine light" keeps coming back on and code indicates the same problem. Any suggestions on what may be causing the light to keep coming on, even after replacing the EGR valve?
Any help would be appreciated.
Thanks,
Dave
Old 09-20-2005, 09:22 AM
KevinM KevinM is offline
KevinM is starting off with a positive reputation.
What code are you actually getting?
Old 09-20-2005, 09:47 AM
Still getting my feet wet on this site. Don't know if my reply got to you ( Kevin ) or not. I sent it personal to you. Let me know, please.
Thanks
Old 09-20-2005, 03:24 PM
ccoram ccoram is offline
ccoram is starting off with a positive reputation.
You have a bad DPFE sensor - if you have a 4.6 you will also need to take off your throttle body and clean out your EGR ports.
Old 09-20-2005, 04:10 PM
Thanks much for taking time to respond. I will try to remedy the situation ASAP.
Old 09-20-2005, 06:38 PM
gmiller0737 gmiller0737 is offline
gmiller0737 is starting off with a positive reputation.
I think ccoram has the correct awnser Ford egr valves rarely fail the most likely cause of PO401 codes is a faulty DPFE sensor (available only from Ford)
Old 09-20-2005, 09:01 PM
Actually you can save yourself a lot of money and if you have the big style DPFE Oreillys sells it boxed as a Borg Warner brand for $47.00. Its the new style black plastic and it is a OEM one. Evidently Borg Warner makes the OEM or the other way around. Its even got the FXXX factory Ford number on it.
Old 09-21-2005, 06:26 AM
thanks ccoram for the info on the oreilly DPFE. i will check into it.
Old 09-21-2005, 07:01 AM
Clif Jones Clif Jones is offline
Clif Jones is starting off with a positive reputation.
I had the same problem with my ford, and it was the DPFE. Just make sure you reset the computor.
Old 09-21-2005, 04:44 PM
thanks to all who were kind enough to take the time to respond to my problem. i replaced the DPFE part and reset the computer. (by disconnecting the negative terminal, for a short while, i was told..) and will see if the "check engine" light comes back on.
thanks again,
dave
Old 09-22-2005, 07:52 AM
have a F-250 with a 5.8 auto, 4WD, that when i start it, i get raw gas fumes through the air vents. i also get no power out of it. first thing in the morning, it's starts good, but after that, it takes a lot of cranking before it starts.
any help would be appreciated.
Old 11-04-2005, 11:18 AM
mdp2110 mdp2110 is offline
mdp2110 is starting off with a positive reputation.
I had the same problem with my 98 Expedition. Last year I replaced the EGR valve, EGR sensor and reset the codes. The light still came back on. Being ignorant I got fed up and took it in to the dealership. $1000 later the check enging light was off. I have to say at this point that they replaced many other things they thought were worn out.
A week before I had to get the inspection done this year the CEL came back on with the same codes, "EGR Flow Insufficient". My friend. I was not going to take it back to the dealership again after last year. I took off the EGR Valve and cleaned it and made sure all the hoses were clear to the EGR sensor. I put it all back together, reset the codes and completed the drive cycle. The light came back on.
I slept on it for a day and looked at all the places the EGR tenticles led. My last resort was to look at the EGR ports that led to the throttle body. I took of the throttle body, for the first time ever and the ports were caked shut with carbon build up. I cleaned them with an old riffle cleaning wire brush, reset the codes and the light has not come back on for a few days now. You may want to try this before buying a new sensor. I would much rather spend the 2 hours it took to clean the ports that lead into the throttle body then to pay the dealership a few hundred dollars to do the same thing.
Only do it if you are confortable with it thought.
Old 11-04-2005, 01:46 PM
FS-150's Avatar
FS-150 FS-150 is offline
FS-150 is starting off with a positive reputation.
Quote:
Davenpt, I too had the same problem with my 2002. Yours is a 4.6 I take it? Does it have low miles? I had about 40k miles on mine when I got the code. DPFE sensor cured it. Mine was done at the dealership for FREE because the warranty was extended for this part. I thought it was mileage limited, but it may be time limited as well. It is worth a shot if you have low mileage. If this is on a high mileage truck, the EGR ports may need to be cleaned as stated above.
Old 11-04-2005, 04:35 PM
chrisindallas chrisindallas is offline
chrisindallas is starting off with a positive reputation.
I have had this in the past. It was caused by a clogged fuel filter. It tripped the sensors.. Try that first and reset and see if it goes away.
Old 11-04-2005, 07:58 PM
jdwheels jdwheels is offline
jdwheels is starting off with a positive reputation.
DPFE sensor? I am slow, what is that?
99 E150 4.2 V6 EGR code TXE150 1968-2013 Full Size Vans 2 01-03-2015 07:10 PM
Insufficient egr flow My Good 'ol 92 1987 - 1996 F150 & Larger F-Series Trucks 5 08-14-2011 01:10 PM
KOEO 334 jellybean66 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 05-19-2011 11:35 AM
code p401 inssuficient egr flow help treehugger1 1997 - 2003 F150 4 09-04-2010 10:10 AM
F150 EGR Flow Insufficient bruening675 1997 - 2003 F150 2 06-06-2010 08:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
