EGR insufficient flow code showing - Page 2 - Ford Truck Enthusiasts Forums
Old 11-05-2005, 08:22 AM
FS-150's Avatar
FS-150 FS-150 is offline
FS-150 is starting off with a positive reputation.
Quote:
Originally Posted by jdwheels
DPFE sensor? I am slow, what is that?
DPFE = Differential Pressure Feedback Exhaust (sensor)
Old 11-05-2005, 04:03 PM
Blue Bonnet Blue Bonnet is offline
Blue Bonnet is starting off with a positive reputation.
if the code is p0401 replace the dpfe sensor
Old 11-07-2005, 09:00 AM
davenpt davenpt is offline
davenpt is starting off with a positive reputation.
thanks for all the info, guys ( or gals). i did end up changing the EGR valve and the sensor, and the light still came back on. i will try the suggestions in order of simplicity, and see what happens. i still only have 33K miles on the truck. seems to run fine. so i don't know if whatever is causing the light to be on, is hurting anything or not. does anyone know if it might be bad to drive while the light is on?
thanks again for taking time everyone...
dave
Old 11-07-2005, 09:04 AM
chrisindallas chrisindallas is offline
chrisindallas is starting off with a positive reputation.
I still say try the fuel filter.. around 15 bucks and easy to change.. I changed my DPFE and also cleaned the ports and finially replaced the egr valve.. No luck.. Then somewhere on here someone suggested the fuel filter. IT WORKED! Just remember to use the fuel cutoff switch or else you will get a mouthfull of gas... (around 10 bucks in gas) lol
Old 11-07-2005, 09:14 AM
FS-150's Avatar
Quote:
Don't forget, you also need a special tool to release the fuel line connectors. If you don't have one already, any auto parts store should have one.
Old 11-07-2005, 10:35 AM
you need someone to clear the codes form the pcm so the light will go out.it will not clear by itself. sometimes disconnecting the battery will work but not always.its not dangerous to drive around with the check engine light on but if something else happens with your emissions system you will not know there is something wrong because the light is still on. so have someone clear it and shut the light out.
Old 07-07-2014, 02:33 PM
guitar_199's Avatar
guitar_199 guitar_199 is offline
guitar_199 is starting off with a positive reputation.
I know I am waking up a really old one here.....
But can someone tell me how a fuel filter can cause a P0401?
99 E150 4.2 V6 EGR code TXE150 1968-2013 Full Size Vans 2 01-03-2015 07:10 PM
Insufficient egr flow My Good 'ol 92 1987 - 1996 F150 & Larger F-Series Trucks 5 08-14-2011 01:10 PM
KOEO 334 jellybean66 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 05-19-2011 11:35 AM
code p401 inssuficient egr flow help treehugger1 1997 - 2003 F150 4 09-04-2010 10:10 AM
F150 EGR Flow Insufficient bruening675 1997 - 2003 F150 2 06-06-2010 08:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
