Tire sizes? - Ford Truck Enthusiasts Forums
Tire sizes?
Old 09-20-2005, 08:35 AM
MARYLAND SMIB's Avatar
MARYLAND SMIB MARYLAND SMIB is offline
MARYLAND SMIB is starting off with a positive reputation.
Arrow Tire sizes?
I've got an 02 F-150 XL sport with 255-16-70's I'd like to have a wee bit more width say a 60 or 65 and not loose gas mileage or rub inside my fenders. So my question is any of yous know about tires. I'm pretty conservative on my likes. But I'd like a little more sport look to it. Yes I know I'll pay more but just looking at my options
Appreciate it
Old 09-20-2005, 09:38 AM
woogs's Avatar
woogs woogs is offline
woogs is starting off with a positive reputation.
I have 285/75/16's on my '02 F-150 Sport. and they don't rub at all. I did lose city milage, but I think I gained hwy milage, less RPM's, not sure though, havn't got a chance to calculate it yet.
all the answers you need are probably in here
http://www.ford-trucks.com/forums/sh...d.php?t=206398
good luck
Old 09-20-2005, 09:59 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
I have 265/75/16's (32") on my XLT 4x4, and there is still room to go with 33's without rubbing. A larger tire will probably make you lose a little MPG around town, but on the highway, it will increase your MPG.
Old 09-20-2005, 10:15 PM
Smaug's Avatar
Smaug Smaug is offline
Smaug is starting off with a positive reputation.
a 295/60/16 will be 1.6 inches wider and less than 1/8 of an inch shorter.
Old 09-21-2005, 08:04 AM
Quote:
Hey thanks I'll give that one a look. Infact I appreciate all of the replys on this.
Cheers.
Old 09-21-2005, 09:31 AM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
I dont know how anyone got a 285 or bigger tire on there f150. I have tried numerous times at the shop. I worked at firestone for 3 years, and I cant tell you how many times we tried to put 285/75R 16s on an F150. everytime they would rub on the inside of the sway bar and stuff. I tred it on my 03 4X4 and it almost fit but once again in sharp turns it would rub. granted you would probably never turn that sharp driving, but it did rub. I also tried it on my 00 f150 with the same results. The only way we could get one to fit was with a small body lift. other than that the biggest tire we could put on at stock ride higth was a 265/75R16. Witch is what I use now. GL
Scotty
Old 09-21-2005, 02:23 PM
woogs's Avatar
Quote:
Scotty
I got mine put on at Discount, they checked one on the front before the put the rest on to make sure they'd fit. they're BFG A/T ko, 285/75/16's. and I've had no problems.
EDIT: I should mention I have an '02 F-150 SPORT, I know the back is lifted slightly, I dunno about the front. that could be the difference.
Old 09-21-2005, 10:58 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
Quote:
good luck
I put 285's on my 97 4x4 and I lost a little in city mileage and did gain a bit ion the highway too.
Old 09-21-2005, 11:46 PM
texans's Avatar
My truck is a sport as well. The problems that I have ran into putting 285's is not in the rear. There is plenty of room in the rear. Its the front. not because of higth. The tire fits under the truck. Its just when you turn the wheel all the way one direction or the other it rubs. I know you would need to turn that sharp most of the time, but I just like to have that ability when I need it. In fact I have put 285's on a 2001 F-150 extendedcab. It looked good, but when I went to back it out of the shop, I turnd the wheel all the way when exiting the shop there it was that real bad rubbing sound. I have tried to put Duller A/T revos and Duller M/T's in a 285/7516 on f-150's with the same result.
scotty
Old 09-25-2005, 11:48 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
The 295 60's are wider but the height is about the same so they may clear ok.
Old 09-26-2005, 07:36 AM
I'll give give it a look. Thanks for all the replys
tire question! SuperDuty93 1957 - 1960 F100 & Larger F-Series Trucks 5 01-06-2014 11:52 PM
wheel spacers for my truck??? all_jacked_up94 1987 - 1996 F150 & Larger F-Series Trucks 5 05-25-2012 12:32 AM
Wheel Spacers? spencer sea 1978 - 1996 Big Bronco 2 03-13-2010 06:56 PM
Help, Tires for a 2003 F150 Sport 2wd supercab??? ronxp2000 1997 - 2003 F150 7 11-21-2008 09:33 PM
08 Sport Trac Limited Stereo Specs? rockstate45 Explorer, Sport Trac, Mountaineer & Aviator 3 08-12-2008 04:43 PM
Tags
2000, 2003, 2005, 2551670, 2857516, 2956016, bfg, biggest, f150, ford, ko, sizes, tire, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
