rough idle when starting..
I have a 2001 F350 dually with 35000 miles..lately when I start truck after it sits the night..the engine idles up and down untill it starts idling fine..Takes 5-10 seconds seems like forever though..rough rough rough rough rough rough smoooooooooooth...Its not cold at night..But If I do plug it in she starts fine every morning..Glow plugs ?Fuel filter?....
Any comments would be great...
Mostly what I have seen cause a cold idle romp is the oil, either from extended drain intervals or low-quality oil.
If you know the oil is fresh and of good quality, you might want to have it checked out. Depending on your in service date, it may still be covered under the 100k-mile warranty.
[QUOTE=MentalState]I have a 2001 F350 dually with 35000 miles..lately when I start truck after it sits the night..the engine idles up and down untill it starts idling fine..Takes 5-10 seconds seems like forever though..rough rough rough rough rough rough smoooooooooooth...Its not cold at night..But If I do plug it in she starts fine every morning..Glow plugs ?Fuel filter?....
This is the Ford broadcast message about the engine lope:
94-03 7.3 Idle Lope on Cold Start:
Ford has determined that the engine loping on a cold start is a characteristic of the engine. They are recommending to use a lower viscosity oil--10W-30 meeting API service CH-4 or CI4--to reduce the condition. They also suggest plugging in the block heater when outside temperatures are below 30 degrees and/or waiting up to two minutes with the key on before starting the engine to allow the glow plugs to fully heat the cylinders. Broadcast Message 1050.
I find when I let the glowplugs cycle for 1-2 minutes, it helps a lot. The 7.3L is a lot of cast iron to heat up. If I forgot to plug her in and she was parked outside overnight even when it only gets down in the 40s, if I don't wait a couple of minutes to turn her over she'll lope pretty bad. I work the hell out of her, so I always run 15W40.
You could also have a glow plug or glow plug relay issue. Try the 2 min. wait and then you'll have a better idea.
Good luck<
Austin
Good luck<
Austin
when I cycle the key to on position, If you turn the radio off and listen, you can hear a hum or buzz that will end with a click (45 sec). if you wait for the click before starting, the romping isnt bad, it does it a couple times and smoothes out. Some guys say its the glow plug relay cycling off when you hear the click, others say its the fuel pump charging the lines back up after sitting a few hours. I dunno, I duncare, it works for me.
Nally427
23
08-12-2013 05:27 PM
