rough idle when starting.. - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-19-2005, 11:16 PM
MentalState's Avatar
MentalState MentalState is offline
MentalState is starting off with a positive reputation.
I have a 2001 F350 dually with 35000 miles..lately when I start truck after it sits the night..the engine idles up and down untill it starts idling fine..Takes 5-10 seconds seems like forever though..rough rough rough rough rough rough smoooooooooooth...Its not cold at night..But If I do plug it in she starts fine every morning..Glow plugs ?Fuel filter?....
Any comments would be great...
Old 09-20-2005, 12:40 AM
big inch big inch is offline
big inch has a good reputation on FTE.big inch has a good reputation on FTE.big inch has a good reputation on FTE.
Mostly what I have seen cause a cold idle romp is the oil, either from extended drain intervals or low-quality oil.
If you know the oil is fresh and of good quality, you might want to have it checked out. Depending on your in service date, it may still be covered under the 100k-mile warranty.
Old 09-20-2005, 12:57 AM
oil was just changed...
Old 09-20-2005, 02:06 AM
AustinS AustinS is offline
AustinS is gaining momentum as a positive member of FTE.AustinS is gaining momentum as a positive member of FTE.
[QUOTE=MentalState]I have a 2001 F350 dually with 35000 miles..lately when I start truck after it sits the night..the engine idles up and down untill it starts idling fine..Takes 5-10 seconds seems like forever though..rough rough rough rough rough rough smoooooooooooth...Its not cold at night..But If I do plug it in she starts fine every morning..Glow plugs ?Fuel filter?....
This is the Ford broadcast message about the engine lope:
94-03 7.3 Idle Lope on Cold Start:
Ford has determined that the engine loping on a cold start is a characteristic of the engine. They are recommending to use a lower viscosity oil--10W-30 meeting API service CH-4 or CI4--to reduce the condition. They also suggest plugging in the block heater when outside temperatures are below 30 degrees and/or waiting up to two minutes with the key on before starting the engine to allow the glow plugs to fully heat the cylinders. Broadcast Message 1050.
I find when I let the glowplugs cycle for 1-2 minutes, it helps a lot. The 7.3L is a lot of cast iron to heat up. If I forgot to plug her in and she was parked outside overnight even when it only gets down in the 40s, if I don't wait a couple of minutes to turn her over she'll lope pretty bad. I work the hell out of her, so I always run 15W40.
You could also have a glow plug or glow plug relay issue. Try the 2 min. wait and then you'll have a better idea.
Good luck<
Austin
Old 09-20-2005, 03:14 AM
Technitom's Avatar
Technitom Technitom is offline
Technitom is starting off with a positive reputation.
when I cycle the key to on position, If you turn the radio off and listen, you can hear a hum or buzz that will end with a click (45 sec). if you wait for the click before starting, the romping isnt bad, it does it a couple times and smoothes out. Some guys say its the glow plug relay cycling off when you hear the click, others say its the fuel pump charging the lines back up after sitting a few hours. I dunno, I duncare, it works for me.
Old 09-20-2005, 08:39 PM
Thanks for info guys...Its just wierd cause it can be 70 out and she does it..But not consistently....
Thanks again..
Old 03-24-2013, 05:18 PM
tattuuuz's Avatar
tattuuuz tattuuuz is offline
tattuuuz is starting off with a positive reputation.
i need help i bought this 1995 dually to pull loads to make money for my family and it idles rough after it warms up for a few mins. and the check engine light comes on
Old 03-24-2013, 08:01 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
Quote:
You need to post this here...I think.
Old 04-10-2014, 11:32 AM
Brian Donoghue Brian Donoghue is offline
Brian Donoghue is starting off with a positive reputation.
Now I'm having the same problem but mine revs up to 1200 rpms then go to normal rpm speed. This happens till I rev the engine to 1500+ rpm then it goes away. Any suggestions on what it is?
Old 04-10-2014, 12:34 PM
HKusp's Avatar
HKusp HKusp is offline
HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.HKusp has a spectacular reputation.
When it does this, is it first thing in the morning and the truck has not been driven for at least 8 hours?
97 f150 drops into rough idle while in drive b.hope014 1997 - 2003 F150 1 03-03-2016 09:45 AM
5.4, 3 valve.. Rough idle Milly1219 2004 - 2008 F150 0 06-11-2014 10:48 PM
5.8 rough idle? Brad_9876 1987 - 1996 F150 & Larger F-Series Trucks 8 10-17-2009 01:19 AM
idling rough 7.3 bassin88 1999 to 2016 Super Duty 1 10-11-2009 08:50 AM
rough idle 88 f150 351w nickh 1987 - 1996 F150 & Larger F-Series Trucks 2 10-21-2007 08:04 PM
Tags
73, 9403, cold, idle, lope, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
