'99 Ranger - battery light flickering? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-19-2005, 11:14 PM
keithi71 keithi71 is offline
keithi71 is starting off with a positive reputation.
The battery light in my '99 Ranger XLT (3.0L, 2WD) recently began flickering during driving and even stays lit completely sometimes. Anyone have any guess what it's trying to tell me? I checked battery voltage with the key off (12V) and with the car running (14V), so I'm not sure what's going on. Maybe a loose cable somewhere? I could swear that the door windows and the wipers seem to be operating just a bit slower, but maybe it's just me. The battery in the truck is the original battery, 128,000 miles, and the alternator is original.
Anyone have any thoughts? Thanks.
Old 09-19-2005, 11:19 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
Probably about time for an upgrade. Just 'cause it's 12 when not running and 14 when running doesn't mean it's in great shape. My suggestion would be to go ahead and replace it with another one. If it's anything like my replacement, the battery was small anyways. Wouldn't say there was a rush though, just when you get the chance.
Old 09-20-2005, 09:02 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
A fully charged battery should read more than 12 volts. Have you checked the battery electrolite level lately????
Shorting battery cells from vibration whle driving, could do it.
A weak belt tensioner could be allowing the belt to slip some while driving.
Bad alternator slip ring brushes could do it.
Loose or corroded battery cables, as you mentioned, could do it.
So it could be a number of things.
If your not into turning your own wrenches or troubleshooting electrical problems, why not run this puppy by your favorite autoparts store, for a no cost in vehicle electrical system check up, via their portable electrical system tester.
It can properly load test the alternator, battery & cables & will likely be able to pinpoint your problem.
Let us know what you find.
Old 09-20-2005, 10:54 PM
Truck died on me tonight...
I drove the truck over to Autozone tonight to have the electrical system tested and the truck died on the way home. While I was at the store, the guy ran a test on the alternator and battery with the truck running - alternator was putting out 11V, battery voltage was 10V or so and dropping rapidly. I kept the truck running - fearing I had little juice left in the battery - and sure enough I only made it another 1-2 miles before the ABS light, brake light and check engine light came on, and then finally, the engine died.
I'm just wondering if the alternator is bad conclusively, or if maybe the battery is on its way out. I'm charging the battery overnight and I'm going to have it tested at a shop tomorrow to see if it's bad or not. I figure if the battery is good and it loses juice again - because the alternator is shot and not charging - then I'm pretty zeroed in on the problem.
Old 09-20-2005, 11:00 PM
Well I'd recharge the battery slowly overnight, then pull the alternator & have it tested separately tomorrow.
Sounds like it's not putting out at all, so be prepaired to fork over some gold for a replacement!!!!
Old 09-20-2005, 11:27 PM
Battery recharge
Actually, I set the charger to fast charge overnight - wasn't sure which setting to use or if it mattered all that much - so will that be safe until around 7 a.m. tomorrow morning when I get to it? I hope so, although the battery is at a garage about three blocks from here (but don't feel like going and changing the setting at this hour if I don't have to!)
Old 09-20-2005, 11:56 PM
Well it's not a good idea to fast charge a battery, nor to run it down very far, nor to recharge it with the vehicles alternator.
I definately wouldn't put it back in the truck tomorow morning & drive it around & run the battery down again.
Every time you do this, it shortens the batteries life.
I hope the battery charger you have set on quick charge, is also automatic cutoff!!!
If not, I'd don my jogging shoes & trot over there right now & check the cell water level & reset it to a slow charge, say not more than 6 amps, the battery would probably like 2 even better.
Yah I know it takes longer, but it also breaks down more of that lead sulfate, which is a battery killer, along with fast charges boiling the electrolyte & warping the plates from too much heat.
So yah gotta make some decisions, square the battery charging away, or you'll likely be buying a new battery before winter is over!!!! IMHO
Anyone know how to test and Alternator proudfrog Excursion - King of SUVs 29 07-01-2016 08:49 AM
Lights Flickering... 1968 F100 Ranger 1967 - 1972 F-100 & Larger F-Series Trucks 21 01-25-2015 04:53 PM
Help! 99 f250 alternator charging problems mck99f250 1999 to 2016 Super Duty 2 06-15-2011 08:38 PM
flickering lights JoSHN Explorer, Sport Trac, Mountaineer & Aviator 3 11-08-2008 08:56 PM
Headlights and dome light have slight flicker at idle Octane 1999 to 2016 Super Duty 4 12-19-2006 02:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
