Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-17-2005, 08:43 AM
TallPaul's Avatar
TallPaul is starting off with a positive reputation.
What changed in the 3.0 for 1993?
Ford put out a chart showing what engines could use 5w20 oil. For the Aerostar 3.0 it showed 1993 and newer could run 5w20. Why did they not say the 1992 could use 5w20? Was there a change to the engine in 1993 that enabled the back specifying of 5w20 for that engine, but not the 1992 and earlier?
__________________
'95 F150 XL, 2wd, 300 I6, 5 speed, 3.08 gear, 151,000+ miles, Flowtech Raptor muffler, driven hard for fun!
'92 Aerostar 3.0 Vulcan V6, auto, 133,000+ miles, Dynomax Super Turbo muffler
www.HonestEdu.org
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-17-2005, 07:14 PM
Rockledge's Avatar
Rockledge has a very good reputation on FTE.Rockledge has a very good reputation on FTE.Rockledge has a very good reputation on FTE.Rockledge has a very good reputation on FTE.
I think '92 or '93 was the first year of the revised (hyrdaulic to roller) block, cam and lifters.
I would bet that has something to do with it.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #3 (permalink)
Old 10-26-2005, 12:34 PM
baddraw is starting off with a positive reputation.
You are correct Rockledge.
  #4 (permalink)
Old 11-18-2005, 11:27 AM
TallPaul's Avatar
Hee hee, I am running 5w20 anyway, but don't be alarmed, it's Redline and has an HTHS higher than many 30 weights.
__________________
www.HonestEdu.org
  #5 (permalink)
Old 12-16-2005, 11:50 PM
mikemic is starting off with a positive reputation.
I think the engine also went away from rotor/distributor and got electronic ignition in '93. not sure if that's relevant.
  #6 (permalink)
Old 03-29-2007, 08:01 AM
elite64a is starting off with a positive reputation.
Quote:
Nope mike the 1993 still has a rotor and distributer
__________________
gone fishin
  #7 (permalink)
Old 08-12-2007, 08:21 PM
ridgerider3's Avatar
ridgerider3 is starting off with a positive reputation.
Heres what I got {a small part of the article};
CRANKS
There have been only two crankshafts used in the 3.0L motor since 1986:
1986-1994
The original E6AE crank with four counterweights - two in the front and two in the back - was used up through '94.
1995-2003
A new casting that had an additional, narrow counterweight in the middle of the crank was introduced in '95 and has been used ever since. The original crank with the extra counterweight was a F58E-AA casting, but there have also been F5DE and XF1E-AA/DD castings with the fifth counterweight that are very similar and completely interchangeable. We expected that the XF1E-AA/DD would be slightly different because it came with the lighter pistons that were used in the 2002-'03 engines, but it checked out the same as the others on the balancer, so it can be used in any motor after '95, too.
No real reason there.
Blocks
1989 - 1991 (except '91 Probe)
Ford added an extra threaded hole on the driver's side that was located right above the pan rail, just below the motor mount, and about 2 inches forward of the bell housing. These blocks still had the four studded main bolts and were used for all the cars, trucks, and vans including the FWD Probe up through '90. Look for an E9DE or F0ZE casting.
1992-1994 (except tempo/topaz with a/t)
All the 3.0L motors except the Probe got roller lifters in '92, so there was a new F2DE casting that had two more bolt holes in the valley that were needed for the "spider" that kept the roller lifters perpendicular to the cam.
Quote:
Rockledge; I think '92 or '93 was the first year of the revised (hyrdaulic to roller) block, cam and lifters.
Must be the reason, not really sure though.
__________________
1982 F-100 248,000+ miles on frame/rear, 300 L-6, SROD 4 speed, 2.75 rears, Flat black hardware store spray cans paint job, 19mpg @65mph with a damn 1BBL!!!
'92 Aerostar with 170,000+ miles and a "junkyard" crank swap to keep her running.
Member Delaware Chapter
http://community.webshots.com/user/jgoldsberry
  #8 (permalink)
Old 12-01-2007, 04:20 PM
TallPaul's Avatar
Well if it's the roller lifers, and the '92 Aerostar has them, then the back spec of 5w20 should have applied to '92. No matter I don't think I would subject any engine to 5w20 unless for short winter trips or if it's Redline.
__________________
www.HonestEdu.org
  #9 (permalink)
Old 01-23-2008, 07:24 PM
jrwrocks is starting off with a positive reputation.
ford has HAD oil problems the passage ways tend to clog thats why they went too 5w20
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
