Battery Drains
Welcome to FTE!!!
The best way to check for this type of a problem is to put an amp meter inline at the battery and see if there is an excess draw, the PCM has a very small drain, 0.05amps. If you find more then make sure you don't have a light, etc on, then start pulling one fuse at a time, remember you have two fuse boxes, until you find the problem circuit.
If you don't have a multimeter to measure for excessive parasitic drain, which could be any of the things Ken outlined but could also include shorted battery cell/s, shorted or leaky alternator diodes, which are more dfficult to test for, why not consder running this ride by your favorite autoparts store, for a no cost electrical system checkup, via their portable electrical system tester.
It can properly load test the battery & alternator in the vehicle, to detect weak battery cells or alternator diodes, as well as check the electrical system for excessive parasitic drain.
Just another idea for consideration.
plum bob
18
05-31-2018 12:06 PM
