hinge lub, etc - Ford Truck Enthusiasts Forums
hinge lub, etc
Old 09-15-2005, 10:35 AM
fiend138's Avatar
fiend138 fiend138 is offline
fiend138 is starting off with a positive reputation.
hinge lub, etc
36 month scheduled maintenance lists, among other things, lubricating the hinges, latches, locks, and weatherstripping. Any suggestions on what type of lube? And how do I lub the locks?
Thanks!
Old 09-15-2005, 11:07 AM
lancekilgore lancekilgore is offline
lancekilgore is starting off with a positive reputation.
It all depends on the envionment you live in as to what lub, in a desert envionment you want a dry lub bou wd-40 or equivaent works in most envionments. just a quick spray. in side the door locks is easy use the rec spray hose that comes with the lub can and a small squirt inside the lock.
Lance
Old 09-15-2005, 11:10 AM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
alchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to beholdalchymist is a splendid one to behold
Quote:
Lance
I NEVER use anything but powdered graphite on my door locks......
Old 09-15-2005, 11:23 AM
fiend138's Avatar
What about the weather-stripping and hinges?
Old 09-15-2005, 11:27 AM
I don't do anything to the weather seals, in my experence if some thing is applyed ti the weather seals then you have to continue the use or it will dry out. the dry lub works best on door hinges but people also use the reg lub for it. There are a lot of preferences as to what is used. in my opinon it boils down to what you like. kind of like the different oils for the engine.
Lance
Old 09-15-2005, 12:34 PM
rlburns rlburns is offline
rlburns is starting off with a positive reputation.
Late-model Volkswagens seem to have a lot of issues with their door seals "creaking". My 2002 Jetta never developed the problem, but I didn't keep it that long. However, 2002 Expedition does seem to have some creaking noises coming from the seals as I drive over rough pavement.
The solution for the Volkswagen problem was to dust plain talcum powder on the seals. This seemed to keep the seals dry so they wouldn't stick to the paint when the door moved relative to the frame. I may try this on my Expy to see if it solves the problem.
Bob...
Old 09-15-2005, 12:48 PM
a type of silicone for rubber can be used as well it lubrictes the rubber, but as I said it should be used or it will dry out the rubber worst if not used again. Oh by the way if you have a sticking window when going up or down silicone works great.
Lance
Old 09-15-2005, 12:51 PM
fiend138's Avatar
Yeah, I called a Ford dealer and they said they use a clear silicone spray for the weather-stripping.
Thanks guys!
any anal lub for my v6? Taunus Oil & Lubrication 15 01-02-2009 08:05 PM
74 4x4 speedo cable is irratic and jumping around. hotroddually 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-21-2005 12:37 PM
90 weight good for a Dana 3:50 1967 F-100 stepasideman 1967 - 1972 F-100 & Larger F-Series Trucks 2 07-08-2005 09:10 PM
no lead gas should i worry ct.russ 1967 - 1972 F-100 & Larger F-Series Trucks 10 06-29-2005 10:45 PM
rubber bushing squeak fishalot Garage & Workshop 7 09-21-2002 08:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
