Replacement For Platinum Plugs.
It boils down to how much your time is worth. If you don't mind replacing the spark plugs every 20K, then you don't need to run platinums.
The reason that double platinum plugs - and now the newer FM "fine metal" plugs - are recommended by Ford is because they will last longer than other plugs. Lasting longer means maintaining the proper gap longer, and plug gap is an example of something that can directly affect engine performance.
Keep in mind that the Ford DIS/DIS ignition sytems are of the "waste spark" design, which means that the spark plugs are firing twice as often, and with a different polarity each time. The Motorcraft DPs and FM Series plugs were designed especially for DIS/EDIS.
John with beastly 302
11-20-2011 09:50 PM
LARIAT 85
02-25-2010 09:16 AM
