Questions/Opinions about gear swap! - Ford Truck Enthusiasts Forums
Old 09-14-2005, 07:24 PM
stang3O2 stang3O2 is offline
stang3O2 is starting off with a positive reputation.
Ive got a 02 FX4 5.4L, stock 3.55s but is lifted now with 315/75/16s (35") tires. This is turned obviously dropped my gear ratio down to about a 3.20 or so. I am debating on new gears considering the trucks tranny works much harder now and is more sluggish as you all know. Quesion...if I put a set of 4.10 gears in my truck...will it actually in turn be a higher gear ratio more around a 3.73 because of the bigger tires. And if I opt to go 4.56 gears...will it actually be more a 4.10 ratio due to the 35" tires. Does anyone have gears in a truck similar to mine, 35's with stock 3.55 gears, whats your opinions on the swap? Thanks...
Old 09-14-2005, 08:40 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
I think that a gear swap is always a good idea if you feel you need more get up and go, and it is definatly good for the 4x4in'!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
