Heater Core - AGAIN! - Ford Truck Enthusiasts Forums
Old 09-14-2005, 07:55 PM
banjopicker66 banjopicker66 is offline
banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.
I had the heater core replaced in my '98 F-150 with a 4.6 last October. The original one lasted 6 years and 110K miles, and now the replacement has gone bad again! The dealer in Augusta, GA did all the work, including a system power flush.
I moved from SC to MD last December, and the MD dealer tells me that the warranty is 12K miles or 12 months - and I have driven over 15K miles, so it is out of waranty.
Help! I cannot afford to spend $800 evey year for heater cores! I don't have time to fix my truck, as I am on the road now.
Any answers? Any suggestions?
Old 09-14-2005, 09:17 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
Did it rust out? I've heard that additional grounding of the heater core can prevent electrolysis, but it's too late for that now.
Old 09-14-2005, 10:24 PM
Smaug's Avatar
Smaug Smaug is offline
Smaug is starting off with a positive reputation.
Hate to hear it. I replaced mine in about 10 hrs. I wasn't about to pay a dealership $700-800 to put in $50 worth of parts. Which dealer did yours?
Old 09-14-2005, 11:24 PM
Bobby Jones Ford did it, and they did a really good job. It just doesn't seem right that the replacement lasted less than a year!
By the way I am working on getting another job in Augusta. I wanna go home!
PS: Deo Vindice, TOO!
Old 09-15-2005, 12:41 AM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
If that was me I would be really mad it only lasted a year, but I also would have spent whatever time it took to put it in myself, just cause I am a little cheap that way.
Old 09-15-2005, 01:18 AM
Smaug's Avatar
I usually take mine to Fairway (recalls), never heard anything bad about Bobby Jones, Fairway is just a lot closer. I bought a factory replacement from Fairway last December and put it in. No problems so far (knock on wood). Hope you can get back down here b4 winter hits. There's something up there they call snow, supposed to be some slippery stuff
Old 09-15-2005, 09:02 AM
ccoram ccoram is offline
ccoram is starting off with a positive reputation.
Ive had a lot of problems with the Fords eating heater cores. Theres a TSB about electrloysis eating the heater cores. Basically just need to add grounds as mentioned before in this post. I would also put an additive in your coolant to prevent it as well.
Old 09-15-2005, 09:46 AM
Can you point me to the TSB? I can't seem to find it on the Internet.
Thanks for any help!
Old 09-15-2005, 10:16 AM
lancekilgore lancekilgore is offline
lancekilgore is starting off with a positive reputation.
I agree with the electroisis, if you just want to get home to fix it your self loop the two hoses together and bypass the heater core, then fix when you get home.
Lance
Autoenginuity near Augusta, GA SC_Hoaty 6.0L Power Stroke Diesel 0 11-02-2012 05:33 PM
Dwayne Augusta, GA E99 F250 Long bed Ext cab 1fixitman Georgia Chapter 1 08-28-2012 03:40 PM
Heater Core Cloggs SuperRocktop 1978 - 1996 Big Bronco 3 12-16-2010 11:04 AM
Gurgling Sound From Heater Core khilding 1978 - 1996 Big Bronco 15 11-27-2008 12:39 AM
1997 F150 abs mpjazztrump 1997 - 2003 F150 2 09-11-2003 01:18 AM
Tags
cores, eating, ford, heater, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
