GEM module? - Ford Truck Enthusiasts Forums
GEM module?
Old 09-14-2005, 12:59 PM
germanbrave germanbrave is offline
germanbrave is starting off with a positive reputation.
GEM module?
where is the gem module located so i can reset it and get my doorlocks working again?
Old 09-14-2005, 05:10 PM
touchofgrey touchofgrey is offline
touchofgrey is starting off with a positive reputation.
Quote:
I can only tell you about the 99.5 to 2003. It is located on the back side of the fuse box. You can either open the dash up to get to the connectors you will need to disconnect. It involves the unsnapping of the section that the headlight switch is installed in. Or you may be able to drop the fuse box and maybe get to them that way. I do know that there isn't alot of slack in those wires. Hope this helps.
Old 09-14-2005, 08:34 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350 RAMPAGE_F350 is offline
RAMPAGE_F350 has a very good reputation on FTE.RAMPAGE_F350 has a very good reputation on FTE.RAMPAGE_F350 has a very good reputation on FTE.
I need to do the same thing, what does the GEM/CSM look like? I want to make sure I'm unplugging the right thing. If it has more than one connector which one do I unplug? Also, how long should I wait before reconnecting? Any help would be appreciated.
Old 09-14-2005, 09:55 PM
Quote:
It's a black plastic box, about 1" thick, about the size of the fuse box, with two multi-pin connectors going in the left side.
Old 09-14-2005, 10:34 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
The 02 and 03's don't have a GEM, they have a VSM. It's behind the lower center dash trim panel, and it has three connectors.
Old 09-14-2005, 10:39 PM
Quote:
Thanks Cookie......my mistake.......I thought they were all the same.
Sorry guys.
Old 09-14-2005, 11:11 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Wouldn't disconnecting the batteries and grounding the cables together accomplish the same task?
Old 09-15-2005, 09:07 AM
Being that I have a VSM and not a GEM, would Kwik's idea of unplugging the Batts do the same thing? Or do I go VSM hunting?
Old 09-15-2005, 01:25 PM
When you remove all power from the truck........nothing will stay alive after about 20 minutes. So yes, it would be the same thing........if a reset is all that's needed.
Gem module Wrecking ball 1999 - 2003 7.3L Power Stroke Diesel 11 06-27-2016 07:52 PM
GEM MODULE sleepyhead416 1999 - 2003 7.3L Power Stroke Diesel 2 05-17-2013 10:16 AM
GEM module location? plgebbia 1999 - 2003 7.3L Power Stroke Diesel 7 07-26-2011 07:00 PM
GEM Module source slickwilly 1997-2006 Expedition & Navigator 6 09-14-2004 06:41 AM
Anti Theft & GEM Module jakegypsum Explorer, Sport Trac, Mountaineer & Aviator 4 03-27-2004 11:07 AM
Tags
2000, 2001, f150, f250, f350, ford, fordgemmodule, gem, located, location, module, reprogram, reset, rotunda, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
