1997 f-250 LD ABS question - Ford Truck Enthusiasts Forums
Old 09-13-2005, 10:32 PM
nascar88ford nascar88ford is offline
nascar88ford is starting off with a positive reputation.
did a search and didn't find an exact match- the other night i was driving home and noticed the brake lights were stuck on. i pulled over and checked the connections on the brake light switch and it was connected. when i got back in the truck i started it up and the ABS light was on. will a bad brake light switch do this? i tried to compare the brake light switch to the one on my 2000 f-150 but it is different. thanks in advance.
-matt
Old 09-13-2005, 10:57 PM
befuddledguy befuddledguy is offline
befuddledguy is starting off with a positive reputation.
Yes - according to TSP 417-01 a bad brake light on/off switch can cause this problem. It's the Brake ON/OFF (BOO) Switch C252. According to the TSP if you turn your ignition key to ACC and your brake lights are illuminated then you have a bad BOO Switch - Hope this helps...
Old 09-14-2005, 08:13 AM
thanks- thats what i thought it was but i wasn't sure. i just thought if there was a problem with the brake light switch the ABS light would flash- but you learn something everyday! thanks for the help.
-matt
Old 09-14-2005, 10:24 PM
found the problem- we put a cheap trailor brake controller on our f-250LD. it turns out that the button that you press to apply the brakes was jammed in and when i pulled over that night i started the truck back up the ABS computer must have thought there was something wrong with the brake light switch. i did not know that button when pressed also illuminates the brake lights. oh well- it is fixed- thanks for the info befuddledguy, i'm sure i will use it someday!
-matt
Old 09-15-2005, 09:08 PM
No problem - glad it was something simple! - Take care...
Tags
1997, abs, brake, f250, ford, ld, light, motor, section, stuck, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
