Ticking noise question
Have a 92 F-150 with the 4.9L, Auto, A/C, 72,000 miles. Just recently has begun having a ticking sound toward the rear of the engine. It has always been alittle noisy, but this is new. I am thinking it is probably a lifter, but the ticking sound is only about 3 per sec, or around 180 a minute. This engine idles at about 750 rpm. If this noise was a lifter wouldn't the sound be more frequent? Do injectors make a ticking sound as they wear? Also if it is a lifter would it hurt anything to try a cleaner like Marvel Mystery Oil? If needed is it difficult to replace a lifter? This truck has EFI. Thanks for your time.
Wik
You are the man, finally had time to really investigate the ticking noise. I can't believe it, but it was a loose sparkplug. I was all ready to start taking off the air induction system to get to the valve cover tonight, when I found that loose sparkplug. What a sweet noise to hear that rumbling six without that dang tick. Thanks to all that responded, but Wik you were right, a loose sparkplug does sound like a lifter tick.
The bombs got some weird noises coming from it too. I get some tick too, but i suspect its the the injector(s) that got a bad case of the squirts. I get a little gas in there too, gotta change em soon. The valves get a bit a noice from time to time, like a startup or once wormed up like at a stoplight its gets a slower raaat raaat raaat raaat noise kind of like a diesel. Sounds like a well broken 300 with sawdust ticks and rats.
thegreatgate
02-09-2015 06:30 PM
