SuperCrew plastic bed rail removal - Ford Truck Enthusiasts Forums
Old 09-13-2005, 08:22 PM
Bobtailfan Bobtailfan is offline
Bobtailfan is starting off with a positive reputation.
Team,
I'm sure this has been posted b4, but I could not find it. Is a "special tool" required to remove the plastic bed rail protectors on a 2001 F-150 SuperCrew? Or is it one of those deals where you distroy the clips and have to replace them?? Any help is appreciated.
Thanks,
TK
Old 09-13-2005, 09:12 PM
ccoram ccoram is offline
ccoram is starting off with a positive reputation.
No special tool - just pull. With the one on the tailgate it has some clips down on the bottom of the edge inside the bed you have the get undone. They are push in cips if I remember correctly.
Those things are pretty much one time use - taking them off usually damages them - turns the plastic that real light grey around your clips if your lucky enough not to break them.
Old 09-14-2005, 05:18 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
On the tailgate cap you can open the access cover and release the clips without damaging them.
Bed rail caps or spray on caps? chesster51 1987 - 1996 F150 & Larger F-Series Trucks 10 02-10-2015 01:27 AM
Are there stake holes and how do find them when there is a rail cap? chuck3mc 2009 - 2014 F150 13 06-29-2013 03:34 PM
fuel rail removal NekSiwel Fuel Injection, Carburetion & Fuel System 5 03-05-2008 12:35 PM
Any tips for removing platic bed rail caps? Beerstalker 1999 to 2016 Super Duty 5 10-08-2007 01:27 PM
LINE X over the rails of my SCREW? Screwchief 2004 - 2008 F150 3 02-01-2004 12:22 PM
Tags
2002, bed, bedrail, f150, factory, ford, molding, rail, railcap, rails, removal, remove, removing, supercrew, tailgate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
