hard to start problem - Ford Truck Enthusiasts Forums
Old 09-13-2005, 07:55 PM
rconstantino rconstantino is offline
rconstantino is starting off with a positive reputation.
Cool hard to start problem
About three months ago my 01 f-150 began starting hard when cold. The engine turns over several times before firing and starting, I hear the fuel pump "click" when I turn and hold the key on. I started with the easy fix changing the plugs and wires, this did nothing. I then changed the fuel filter and this too did not help. After taking the my truck to a garage I have since had the fuel pump and fuel pressure regulator changed, both of which have yielded no results.
Could this be a pressure issue with fuel lines or gas cap? I have exhausted all of my knowledge on this issue and am very frustrated at how expensive this problem has become. Please Help!!
Old 09-13-2005, 07:58 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
you need the truck scanned for codes with a deep scanner.
Old 09-13-2005, 08:02 PM
I had the truck scanned and it returned a p306 - misfire on cylinder six? Is this what you meant by a deep scan
Old 09-14-2005, 06:40 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome rconstantino, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
