10.5 axel ate a set of spider gears.
My 01 SD F250 with V-10 and an open 10.5 dif with 3.75 gears got very sloppy. I pulled the cover off and raised one tire off of the ground. By rotating it back and forth it was obvios the play was in the spider gears and pin.
I replaced them with a Yokon spider replacement set and problem solved.
Any body else have this happen at only 50,000 miles?
ramair428cjxr7
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
03-17-2015 01:15 PM
