General Question on older Bronco II - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 09-13-2005, 11:15 AM
thomj1 thomj1 is offline
thomj1 is starting off with a positive reputation.
This is a general question on older Bronco II (mine is a 1986 with 220K)...
-Should I run these hi-tech plugs; Single or Double platinum, etc. It appears to me that the $1.99 Motocrafts give me better life in my car??
-Should I run any of these oil additives (the kind you see on the counter at auto stores with the gears you crank and see how the oil sticks to the one set of gears better - I can not remember the name of the product) that increase engine protection for hi-milage cars? Or will this just gum the engine up.
-Is there any advantage to running higher octane fuel in this vintage car??
Like I said, just want to get someone elses opinoin on this. Thanks in advance
Old 09-13-2005, 04:18 PM
GrayRanger4x4's Avatar
GrayRanger4x4 GrayRanger4x4 is offline
GrayRanger4x4 is gaining momentum as a positive member of FTE.GrayRanger4x4 is gaining momentum as a positive member of FTE.
If you run any other plugs then the motorcraft standerd copper ones I would just run the single platinum ones.{thats what I'm useing with no problems}
As far as oil additives go I would not use any.Just run a GOOD 10W30 oil and a Motorcraft or Wix oil filter.JMO
Old 09-13-2005, 07:21 PM
bronco2man bronco2man is offline
bronco2man is starting off with a positive reputation.
Smile
I'm running shell rotella 15w40 in both of my broncoIIs', keeps the oil pressure up
Old 09-14-2005, 12:47 AM
RomerB2's Avatar
RomerB2 RomerB2 is offline
RomerB2 is gaining momentum as a positive member of FTE.
I'm running the Bosche 4 way type, they work really well too. I have those, 8mm wires, brass cap and rotor, and MSD Blaster-3 coil. No problems here. As far as oil, I personally use Valvoline and I stay away from Pennzoil, I've heard horror stories, but that's just my opinion.
Old 09-14-2005, 01:01 AM
Monty06 Monty06 is offline
Monty06 is starting off with a positive reputation.
i was using bosch platinum 4 plugs but decided for autolite iridium plugs instead with 8.8mm msd wires and ignition sysem. i work parttime at advance auto parts here in miami and i have used lucas oil additive that's what your talking about the little machine with the gears. i run 20w-50 castrol with a k&n oil filter i have no problems with ticking lifters or loss of oil pressure.
Old 09-14-2005, 07:50 AM
Thanks for all the input and insight!!
MSD Question:
I just installed a new set of Bosch wires (not sure if 8mm). Will the MSD system work on a '86 BII 2.9L EFI? What would I need to change out - just replace my 19 yr old factory ignition coil with a MSD one?
Old 09-14-2005, 04:03 PM
you have a 8227 msd coil direct replacement for stock coil. you need to find yourself
a 8874 wiring harness from msd and a msd 6A or 6AL with rev limiter.
works great.
Old 09-14-2005, 09:31 PM
Great! Thanks for the help!
1987 Bronco II Project BroncoNoob Bronco II 9 11-07-2009 05:51 PM
bronco II headlight adjustment ford_nut2000 Bronco II 1 02-21-2007 10:11 AM
bronco II or escape? bronocIInoob Escape & Escape Hybrid 19 02-28-2006 07:57 PM
gurgling noise heard from dashboard hvnitro006 Bronco II 15 12-16-2005 11:13 PM
A4LD tanny is DEAD....NEED HELP !!! VWandSTUDEBAKER Clutch, Transmission, Differential, Axle & Transfer Case 6 06-01-2003 03:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
