Rough running 5.4 - Ford Truck Enthusiasts Forums
Rough running 5.4
Old 09-13-2005, 09:50 AM
fordguy4life fordguy4life is offline
fordguy4life is starting off with a positive reputation.
Rough running 5.4
Hi guys. I've got a problem with my '99 5.4 w/124000. Every once in awhile the truck will run rough when it's idling or shifting into OD. I replaced all of the plugs at about 90,000 when it was really running rough. I got check engine diagnostic codes then, for COPS, but not now. Changing the spark plugs took care of it the last time. I would think I would get a COP code if that was the problem. Any ideas? Thanks.
Old 09-13-2005, 02:18 PM
4dzilla 4dzilla is offline
4dzilla is starting off with a positive reputation.
I would start with the basics like a new fuel filter and clean the maf sensor. Wouldn't hurt to check the air filter either.
Old 09-14-2005, 10:22 AM
I was thinking maybe injector related. Any thoughts on this?
BANK#1 too lean & misfir cyl #2-Help with possible problems please westflgator 1997 - 2003 F150 5 11-30-2011 11:06 AM
5.4, runs like bad c.o.p. or bad plug, no codes or pending Kurts74ford Modular V8 (4.6L, 5.4L) 26 01-09-2011 10:58 AM
97 F150 5.4 good cop bad cop whoduhmann 1997 - 2003 F150 10 09-23-2008 07:29 AM
07 4.6L COP or new motor Ropes4u 1997 - 2003 F150 4 07-22-2007 11:17 AM
Spark Plugs & COP's ????? crew02 1999 to 2016 Super Duty 9 06-29-2007 11:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
