Turbo charger surging
NEED HELP
I am experiencing a problem w/my 2003 6.0 super duty. While driving on a level road and maintaining a constant speed, the truck surges slightly as if the driver is pressing and releasing the throttle pedal. I have a boost gauge installed and the boost surges approx. 2 psi. You can hear the turbo whine up and down in concert w/ the boost gauge increase and decrease. It appears the truck in being told to accellerate and decellerate. Ther is no surge when the truck is goung up a grade or under a load. It occurs only while driving on a level road while maintaining a steady speed. Makes no difference w/ cruise on or off. The code that pops is a p2263 Turbo Charger System Performance. Any ideas what may be causing the surge?
Make that 2 of us (need help)
I have an early 04 f250 doing the same thing. It does not do it everytime I take off, but I would say 2 out of ten times. It feels like either the turbo is kicking up or the fuel injection is flicking on and off. It's a bucking feeling. I've had the in the truck in the shop going on for the 3rd time to get this fixed. Can anyone out there tell me what's going on. Then, maybe I can tell ford how to fix it finally. Go figure!
Oh, by the way, I got my idle problems fixed. woo hoo. I will give Payton Wright Ford some kudos, they are at least willing to work on it. Changing dealerships was some what helpful. Thanks forum.
This info is from the Ford website in reference to code P2263
18694 2003-2006 F-SUPER DUTY/2003-2005 EXCURSION/2004-2006 E-SERIES - LACK OF POWER AND/OR DTC P2263 OR P0299 AFTER TURBOCHARGER REPLACEMENT - SERVICE TIP
SOME 2003-2006 F-SUPER DUTY, EXCURSION, AND 2004-2006 E-SERIES VEHICLES WITH A 6.0L DIESEL ENGINE MAY EXHIBIT A LACK OF POWER AND/OR DIAGNOSTIC TROUBLE CODES P2263 OR P0299 (TURBOCHARGER BOOST SYSTEM PERFORMANCE) AFTER TURBOCHARGER REPLACEMENT. TO SERVICE, CHECK THE OLD TURBOCHARGER TO MAKE SURE THE TURBINE WHEEL IS STILL INTACT. IF THE TURBINE WHEEL IS MISSING, CHECK THE EXHAUST TUBE BETWEEN THE TURBOCHARGER AND THE CATALYTIC CONVERTER FOR THE MISSING TURBINE WHEEL. THIS WHEEL IS OFTEN STUCK IN THE DOWNWARD BEND JUST BELOW EYESIGHT LEVEL. REPAIR AS NECESSARY.
EFFECTIVE DATE: 06/24/2005
18525 2003-2005 F-SUPER DUTY/EXCURSION AND 2004-2005 E-SERIES - UPDATED DIAGNOSIS - DTC P0299, P2263, P0401 (EBP SENSOR)
SOME 2003-2005 F-SUPER DUTY, EXCURSION, AND 2004-2005 E-SERIES VEHICLES WITH A 6.0L ENGINE MAY EXHIBIT ANY ONE OR MORE OF THE FOLLOWING: BUCK/JERK, LACKS POWER, BLACK SMOKE, ROLLING IDLE, SURGE, MIL ON, AND DIAGNOSTIC TROUBLE CODES P2263, P0299, OR P0401. UPDATED PC/ED MANUAL DIAGNOSTICS FOR THE EXHAUST BACK PRESSURE SENSOR (EBP) ARE NOW AVAILABLE ON-LINE, AND UPDATED EBP SENSORS ARE NOW AVAILABLE FOR VEHICLES BUILT BEFORE 1/17/2005.
EFFECTIVE DATE: 04/04/2005
17508 2003-2004 SUPER DUTY F-SERIES/EXCURSION/E-SERIES 6.0L - FALSE DTC'S SET DURING USE OF ACTIVE COMMANDS WITH WDS
SOME 2003-2004 SUPER DUTY F-SERIES, EXCURSIONS AND E-SERIES VEHICLES EQUIPPED WITH A 6.0L DIESEL ENGINE MAY GENERATE FALSE DIAGNOSTIC TROUBLE CODES (DTC'S) DURING THE USE OF ACTIVE COMMANDS WITH THE WDS. COMMAND OF EGR%, VGT% AND IPR CAN GENERATE THE FOLLOWING DTC'S: P0404, P0488, P0299 (EGR%); P2263, P0478 (VGT%); P2284, P2288, P2289 (IPR). DO NOT USE DTC'S SET DURING THE USE OF ACTIVE COMMANDS TO DIAGNOSE THE VEHICLE CONCERN. IT IS IMPORTANT THAT ALL CONTINUOUS MEMORY DTC'S BE ERASED FOLLOWING DIAGNOSTICS USING ACTIVE COMMANDS. NOT CLEARING THESE DTC'S MAY RESULT IN THE MALFUNCTION INDICATOR LAMP (MIL) TURNING ON AND/OR IMPROPER COMPONENT REPLACEMENT ON RETURN SERVICE VISITS.
EFFECTIVE DATE: 01/23/2004
esalter,
Welcome to FTE.
Check out our Guidelines:
https://www.ford-trucks.com/guidelines.html
And the Read First: notices at the top of each forum, it will help you understand and navigate FTE easier.
See you around...
BigF350<o =""></o>
Welcome to FTE.
See you around...
BigF350<o =""></o>
I have just had this code come up as well. Here is some info I found on another forum on it:
DTC P2263
Condition Description :: Turbo/Super Charger System Performance
Fault Trigger/Comments :: - None -
Probable Causes :: MAP hose, MAP sensor, CAC system leaks, Intake leaks, EP sensor, exhaust restriction, exhaust leaks
For me though, I am 99% sure it is because I have an exhaust brake that I just finished installing and trying out...
DTC P2263
Does your truck surge when the cruise control (if you have it) engaged?
I find that some road surfaces have a subtle bit of ridging in them and combined with your foot on a sensitive fly by wire pedal you can get a slight harmonic type of ride and you with out really noticing it rock on the pedal ever so slightly giving a slight jerky feel.
It may be nothing more than your foot beating time to the road???
johull
1999 to 2016 Super Duty
11-08-2009 04:47 PM
johull
11-08-2009 01:02 PM
