door locks always locking - Ford Truck Enthusiasts Forums
Old 09-12-2005, 12:56 PM
78 short 78 short is offline
78 short is starting off with a positive reputation.
What's the deal with these door locks.I drive a 2002 sc4x4 xlt.....Every time I drive the truck the locks lock and when I stop they unlock just drivers side.This is always making me mad as my passengers are always asking to let them in because it's always locked.My manual is in french only,which I can't read very well....HELP!!!!
Old 09-12-2005, 01:27 PM
ccoram ccoram is offline
ccoram is starting off with a positive reputation.
Same problem on my truck just a couple of days ago.. it was a bad drivers side lock/unlock switch. Try unplugging it and see if it still happens. If not, thats your problem. You might be able to "reset" the switch - mine quit when I unplugged it and never did when I plugged it back in but I replaced it anyway.
Old 09-12-2005, 01:34 PM
I'm comfused.If I umplug the switch it's not going to lock either.I just want it to unlock with the other locks.It locks just fine every time I drive.All locks unlock every time I put it in park except the passenger door.
Old 09-12-2005, 01:35 PM
I guess what I'm trying to say ...Are all doors suppost to unlock at the same time when it goes into park???
Old 09-12-2005, 01:38 PM
mel2000f150 mel2000f150 is offline
mel2000f150 is starting off with a positive reputation.
Look in your owners manual, There is a way to disengage this opt.
Old 09-13-2005, 12:15 PM
befuddledguy befuddledguy is offline
befuddledguy is starting off with a positive reputation.
Expy Does the Same
My wife's Expedition used to do the same thing - locks ALL the doors when you put it in drive - only unlocks the drivers door when you put it in park. She had Viper alarm system installed about two weeks ago - and ever since then when she puts it in park ALL the doors unlock. So I'm not sure what the deal is there... I'm guessing that it's normal & possibly as a safety feature and that my wife's alarm is overriding it?
Old 09-18-2005, 04:21 PM
spidk43 spidk43 is offline
spidk43 is starting off with a positive reputation.
we have an 01 screw that has that option... don't have the manual right now (dad's out fishing) but it's in english and if I can get a hold of it i'll type up how to disengage this option, i like the older trucks where it isn't locked unless you lock it...
Old 09-18-2005, 04:31 PM
here it is, I actually found it on this website--http://ford-trucks.com/article/idx/0/184/article/Safe_and_Secure_How_to_Enable_or_Disable_Your_Auto lock_System.html
1. Start in the truck with all doors closed and the key turned off.
2. Put the switch in the on position and press the door unlock button 3 times.
3. Put the switch in the off position and press the door unlock button 3 times.
4. Put the switch in the on position, you should hear a quick note from your horn.
5. Press the door unlock button 1 time then press the door lock button 1 time.
6. You should hear a short note from your horn indicating that the auto-lock system is disabled. If you hear a short note then a longer note from the horn then the auto-lock system has just been enabled.
7. Turn the switch to the off position. You will hear a short note from the horn to let you know that the system has been changed.
8. These steps should be done within 30 seconds in order to properly activate or deactivate the feature.
The system will in most cases revert back to the original setting anytime you disconnect the battery. I understand that these directions will work on any late model Ford vehicle but I have only performed it on the Ford trucks.
I have also performed this on our '01 screw, it does work.
hope that helps!
~Matt
Old 09-19-2005, 08:32 AM
captain p4's Avatar
captain p4 captain p4 is offline
captain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud ofcaptain p4 has much to be proud of
not sure how to subscribe without posting and i want to try this when i get home..
thanks.
Old 09-20-2005, 03:59 PM
A_Freebird's Avatar
A_Freebird A_Freebird is offline
A_Freebird is starting off with a positive reputation.
Door lock codes
Check out your user manual. You can download your manual in a PDF from the Ford website https://myford.fordvehicles.com. Register your truck if you haven't already and then you can search the manual for the codes. You have to do a combination of key turns in the ignition while you hit the door lock. You can turn it on or off this way at least. There may be more options, I don't know.
Old 09-26-2005, 09:32 AM
Thank's spidk43....That's what I was looking for.Thank's for the effort.I new there was something I could do within the stock program.
Automatic door lock 1amante 1999 to 2016 Super Duty 1 02-26-2014 07:27 AM
Locking problems, 2000 explorer 00Explorer Electrical Systems/Wiring 1 09-24-2013 04:02 PM
Weird electrical problem (door locks and dome light) garbadee Aerostar 13 11-18-2012 10:56 AM
Keeping front hubs locked? 2002exPSD Excursion - King of SUVs 11 02-23-2012 07:43 PM
Alarm And Door Locks Freaked Out!!!!! benjaminokc21 Explorer, Sport Trac, Mountaineer & Aviator 2 09-12-2008 03:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
