Runs Fine - Won't Idle - Help
Old 09-11-2005, 03:42 PM
50th ann's Avatar
50th ann
50th ann is offline
!998 4.6 F-150 Auto 2wd 153,000 Miles
Starts up like always and runs fine so long as I keep it running with a little gas but let up on the pedal and it stalls out.
IAC ? MAF ?
Old 09-11-2005, 03:54 PM
xtrford's Avatar
xtrford
xtrford is offline
Check for a vaccum leak either at your pcv valve elbow or possibly intake manifold, wouldnt hurt to clean the iac with some seafoam deep creep or the maf with some electrical cleaner(very gently I might add).
Old 09-11-2005, 05:00 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Sounds like a sticking IAC to me.
Old 09-11-2005, 05:06 PM
50th ann's Avatar
50th ann
50th ann is offline
Thanks - Great Site
I cleaned the IAC and it's Fixed.
Many Thanks !!!
What a great site.
Old 09-26-2005, 08:46 AM
Viper26's Avatar
Viper26
Viper26 is offline
OK need a little help with the IAC.....
I have the same problem, but could you tell me what the IAC is? I have installed a K&N FIPK kit over this past weekend and now I an experiencing this problem. I'm going to give cleaning it a try once I knwo what it is.....
Old 09-26-2005, 08:51 AM
Fxxer's Avatar
Fxxer
Fxxer is offline
50th ann you may want to just pick up a new IAC because cleaning it is only a temporary fix. I bought one at the dealer, I know the guy, so I only payed $60 but they usually retail around $80.
Old 09-26-2005, 08:54 AM
Fxxer's Avatar
Fxxer
Fxxer is offline
viper 26 I can't seem to find the link but do a forum search on IAC or Idle Air Control valve and you will find what you are looking for.
Old 09-26-2005, 08:55 AM
Viper26's Avatar
Viper26
Viper26 is offline
OK thanks, but do you know what the IAC is? Or what IAC stands for?
Old 09-26-2005, 08:56 AM
Viper26's Avatar
Viper26
Viper26 is offline
Thanks Fxxer, I will do that.
