speed sensor location
Hi all,
I have a 01 ford f150 4.6 L 5 speed....and i can't locate the speed sensor....someone told me that it was on the rear so i looked and their is something on the top of the rear but i'm not positive it thats it or now.....when i took it out it didn't spin so i'm assuming if thats the sensor it's supposed to spin...
any help would be great
thank you
thank you
The speed sensor you are talking about is on the back of the transmission, the speed sensor I am talking about is for the ABS, when the brakes lock up it detects it and keeps the brakes from locking up. the speed sensor for the speedo is on the transmsiion. I beleive it is electrical. not cable mounted. of course this is my understanding of the system. My speedo sensor is on the tranny, (2000 F150 4x4). I of course could be in left field again but I will check my shop manual when I get home.
I do know that if your ABS light did not come on then the sensor on the diff was not the problem if it was bad then ithe abs light would come on.
Lance
Lance
the manual shows the sesor is on the back of the transfer if you have a 4x4. it shold be in around the same location on the transmission on the 2x4. If you buy the sensor then of under and find the equivalant on the transfer or tranny. disconnect, remove and install. reset cpu or clear all faults.
Lance
Lance
