1964 f100 engine swap - Ford Truck Enthusiasts Forums
Closed Thread
Old 09-11-2005, 11:33 PM
kssouth kssouth is offline
kssouth is starting off with a positive reputation.
i reciently got my hands on a 1964 f100 it has a 292 y block.my question is what engines will swap as a bolt in. the original engine has a thrown rod and block damage .do you have to go back with a y block or can a fe engine bolt in
Old 09-12-2005, 06:28 AM
mikecarson's Avatar
mikecarson mikecarson is offline
mikecarson is starting off with a positive reputation.
An FE engine is not a direct bolt in swap. The mounts are different. with the correct adapters, it is a worthwhile swap.
I put a 390 and 4 speed in my 62, the hardest part was being without my only vehicle while I was doing the work!
Old 09-12-2005, 06:50 AM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
ks, Unfortunally no modern engine is a direct bolt up. Another 292 or the 312 found in some cars will work. Those engines are front mount, while modern engines are side mount.
There are conversion kits sold, but you would have to include the tranny in your conversion.
John
Old 09-12-2005, 10:04 AM
thanks for the info .does any body know a good place or two to check on engine mount adapters or conversion kits
Old 09-13-2005, 07:03 AM
jowilker's Avatar
I know Rick carries them http://www.carolina-classics.com/
John
Old 09-14-2005, 05:58 PM
CustomCab4x4's Avatar
CustomCab4x4 CustomCab4x4 is offline
CustomCab4x4 is starting off with a positive reputation.
61-64 Engine adapters
I used a Trans/Dapt kit for my 64 a few years ago when I put a 302 & C-4 in it. Looks just like the ones that Carolina sells. They are very easy to install. Really takes the work out of a swap.
Good luck, Phil
Old 09-15-2005, 09:57 PM
thanks for the info
Old 09-16-2005, 01:18 AM
moiamiervous moiamiervous is offline
moiamiervous is starting off with a positive reputation.
Re:1964 f100 engine swap
kssouth,
I need a passenger side exhaust manifold can I get one from that 292 that has a thrown rod you have ?? I will pay for shipping ??
i reciently got my hands on a 1964 f100 it has a 292 y block.my question is what engines will swap as a bolt in. the original engine has a thrown rod and block damage.do you have to go back with a y block or can a fe engine bolt in
Old 09-16-2005, 07:30 AM
jowilker's Avatar
Sorry guys, Each member has email and some use pm for contact about sale items.
Bossman wants it inforced.
John
Closed Thread
1964 F100 292 Y Block Water Pump vze2c2gb 1961 - 1966 F-100 & Larger F-Series Trucks 25 07-11-2016 11:44 AM
WTB: 1964 Ford F100 292 Oil Dip Stick SanDogDewey WTB - Parts & other 0 02-01-2016 11:00 AM
ECZ-B Heads ? vze2c2gb Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 2 10-14-2014 07:12 PM
Headers for my 292 Y-Block dullchrome Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 6 01-22-2009 01:48 PM
Are all y-blocks the same? bolivious 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 11-16-2006 05:52 PM
Tags
100, 1964, 302, a302, adaptor, conversion, engine, f100, ford, kits, motor, mount, putting, swap, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
