Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-11-2005, 10:19 PM
ravishingdogg is starting off with a positive reputation.
4.2 locked up
my datuter locked up my 4.2 in my 98 f150 iI,m just wondering if this is a prolbem
with this engine ? I have not done anything yet not sure whitch way to go.
she tried to start it an it spin twice them locked.Ithought may it was stater but
tried to kick it off wheels would not turn.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-11-2005, 10:47 PM
Beast12's Avatar
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Hi and welcome to FTE! Be sure to read this to help you around this site: http://www.ford-trucks.com/forums/sh...d.php?t=300691 There are also State Chapters located near the bottom of the main forum page.
Thread moved to 4.2L forum.
It sucks you had to join us because of this problem. I moved your post here where you will get more help.
See ya on the boards!
-Matt
__________________
-Matt (FTE Super Moderator)
2001 F-150 S/C XLT 4x4 Sport
Check Out The Ontario Chapter
"He who is tired of WEIRD AL is tired of life" -Homer Simpson
  #3 (permalink)
Old 09-11-2005, 10:49 PM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.
well the enigne if it really is frozen is toast. sounds like it was run out of oil.
  #4 (permalink)
Old 09-12-2005, 10:58 AM
BrianA's Avatar
BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.
I assume the starter is engaging and trying to turn the motor over, but for some reason, the motor will not turn over.
If this is the case, I'd remove all the spark plugs and see if the engine will turn over. If it will, look for liquid that might be blown out of one (or more) of the empty plug holes.
If all this occurs, then it sounds like the engine was hydro-locked: a liquid (likely coolant) leaked into one or more cylinders (likely bad lower intake manifold gasket) and caused the engine to "lock up" (liquids will not compress like air/fuel mixture will.)
Give it a shot and get back in touch.
Thanks
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Alabama Chapter Leader
  #5 (permalink)
Old 09-12-2005, 12:36 PM
if water got in there it had to of bent the rods so you are looking at a new enigne.
  #6 (permalink)
Old 09-12-2005, 08:59 PM
no water in cyl took out plugs still will not turn .anychance it just bent a push rod
or valve ? or more lickley junk. thanks in advance for all your help.
  #7 (permalink)
Old 09-12-2005, 09:39 PM
try turning it by hand from the crank with a breaker bar. what is the oil level????????
  #8 (permalink)
Old 09-12-2005, 10:11 PM
tryed that it is full of oil .
  #9 (permalink)
Old 09-12-2005, 11:16 PM
BrianA's Avatar
A little more info pleeeze...
What, exactly, was occuring one second before the engine siezed?
Trying to start it?
Cruising down the road?
Doggin' it in low gear.
Bumping redline?
__________________
Brian A
  #10 (permalink)
Old 09-17-2005, 10:05 AM
tryed to start it spun over twice sounded like weak batt then it was locked
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
