Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-11-2005, 07:42 PM
JCATON is starting off with a positive reputation.
quick question
does anyone know how much 285 55 20 tires & 4.10 gears will throw off my spedometer? please help.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-12-2005, 04:18 PM
true4.2 is starting off with a positive reputation.
A lot without a chip.
I'm not expert by any means, but I'd say a good 15 - 20 mph anywhere over 35 to 40 mph. Anything below 35 I'd guess decrease amount by about 5 to 10 mph until you hit 0 mph. Does that make sense? Like I said...not an expert, but it should be fairly close.
I had stock 16" tires and 4.10's, and at 80 mph on my gauge, I was actually doing 70.
__________________
--Joseph--
'08 F350 6.4L
Hot Shot Hauling Truck
  #3 (permalink)
Old 09-12-2005, 11:22 PM
BrianA's Avatar
BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.BrianA has a very good reputation on FTE.
Pick a number, any number. Now divide by 2, add the square root of the number, multiply by.....
Uh, actually I have no Earthly idea.
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
Alabama Chapter Leader
  #4 (permalink)
Old 09-15-2005, 05:31 PM
BlueOvalFitter is starting off with a positive reputation.
Quick question? Are we suppose to read it quick or answer it quick? Sorry,I just had to!
__________________
2007XL R/Cab,4.2 V6,auto
The anticipation of death is worse then death itself!
  #5 (permalink)
Old 09-16-2005, 01:41 AM
4.2manster's Avatar
4.2manster is starting off with a positive reputation.
it all depends on your current setup. a 285/55r20 is a big tire, if you plan on lowering your truck then that is way too big.
285*.55*2/25.4 = 32.3"
My stock 235/70r16 comes out to 28.9"
My current 274/45r20 comes out to 29.7"
much closer.
It all depends on your stock tire size. If you have stock 235/70r 16, and go to a 285/55r20 with 4.10's, you probably wont even notice a difference in MPG/odo (sorry joe, but most ppl with 33"s re-gear to 4.10)
So you'd be pretty close to the stock EFFECTIVE gear ratio, but forget about lowering the truck with that setup. I don't even know if it'll fit under the front wheel wells unless it's a 4x4. That's the tire size most people with Expeditions use when they throw on 20's.
FYI: the HD pickup uses 275/45r20
  #6 (permalink)
Old 09-16-2005, 09:25 PM
sorry i was off ive got 285 50 20 tires. i found out im off by 7.8% on my spedo with my wheels. does putting on new gears mess up your spedo to?
much closer.
  #7 (permalink)
Old 09-16-2005, 09:38 PM
4.2manster's Avatar
285/50r20 is 31.22"
still a bit taller, 4.10's will give you some umph still. Expect an increase in what your speedo reads compared to what you are actually driving at.
  #8 (permalink)
Old 09-17-2005, 01:57 PM
six shooter is starting off with a positive reputation.
Lightbulb
Just get a programmer when you get your gears so you can calibrate your speedo with your tire size. I know the microtuner has that capability.
  #9 (permalink)
Old 09-17-2005, 02:24 PM
4.2manster's Avatar
with any (good) chip, you can tell them your gears and tire size and they will program/flash the chip so that your odo/speedo works properly
  #10 (permalink)
Old 09-18-2005, 01:03 PM
Correct, but I thought that was just to help power and acceleration. Does the added gearing help with 33's instead???
__________________
--Joseph--
'08 F350 6.4L
  #11 (permalink)
Old 09-18-2005, 09:03 PM
4.2manster's Avatar
b/c you are increasing the overall diameter, it's the same effect as putting taller gears. So to offset that, you actually DO put on shorter gears, to try to balance it out.
if at 3000 rpm you are going 10mph
on 33's you would go 12mph
throw 4.10's and you are back at 10mph
And no, those are not actual values!
  #12 (permalink)
Old 09-19-2005, 10:43 AM
Ah I see, thanks for the correction. I = retarded
__________________
--Joseph--
'08 F350 6.4L
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
