Rear ends
The teeth on the pinion and ring gears must mesh correctly to avoid abnormal noise and premature wear.
The relative positions of the gears is adjusted by using shims to set the preload.
This is not a job to be taken lightly. There are special tools which should be used to get it right.
Steve
Steve
