knightcharger,
Wondering if you would mind helping us out by answering a few questions. We are pulling together some information on the 1948-1950 Ford Trucks for a few purposes.
One is to establish the VIN # cut-off between the 1949 and 1950 model years. Another is to determine if there were, in fact, any large window trucks built during these years, whether any of the 1950 trucks had flat sided beds as opposed to the more common (and better looking) raised panel sided beds, and to establish which trucks actually had the column shift three speed. This little project has also morfed into a study of the numbers stamped into the firewall on these trucks.
Questions:
1 - I already have your VIN # from above. Based on the sequence #, it would appear to be a 1949. Ford did not start anew with the sequence # in the VIN's between 1949 and 1950. Consequently, there is often some confuasion over what is a 1949 and what is a 1950. Again, yours would appear to be a 1949.
2 - Do you have raised panel beds?
I woud assume you do because yours is a 1949 and because you have an F2 which continued with the raised panel beds through I believe 1952 or 1953. I am assuming you stil have a bed on your truck.
3 - What transmission do you have?
4 - Is it a floor shift or column shift?
I am assuming that it is a floor shift since it's a 49 but I was hoping that you could confirm.
5 - Do you have the small window that was common on the 48-50's or do you have a larger rear window like in the 51/52's?
Again, I would assume that you have the small window since yours is a 49.
6 - Are you able to locate a series of numbers and letters stamped into the firewall inside the engine compartment? If so, can you provide them to us?
Tim (mtflat) seems to have broken the code for us. The numbers appear to indicate the original paint color, the location of manufacture, the date of manufacture, and a sequence number for either the day (overall) or the week (plant specific). This number is stamped in the firewall and they have been located in a number of places. It could be above the top seam in the firewall or below it. It is usually in the center of the firewall but I've seen it all the way over on the passenger side (US) next to, and partially covered by, the VIN plate. We will gladly provide you with what we believe it indicates. I am particularly interested in yours because it is on the other side of the pond.
7 - Is your truck a US truck that was exported to the UK back in the day or did it get sent over later? Was it built over there somewhere? Do you know anything about the history.
8 - Does your truck have right hand drive or is the steering on the correct side?
I would appreciate any help you can provide. There is a thread at the top of the 1948-1960 forum located in the "READ FIRST Section at the top of the forum, that was set-up to collect this informationbut since the replies have slowed a bit, I'm chasing #'s now.
Thanks and feel free to ask any questions.
Carl G. - a.k.a. - Texan2004
