Runs Fine - Won't Idle - Help - Ford Truck Enthusiasts Forums
Old 09-11-2005, 03:42 PM
50th ann 50th ann is offline
50th ann is starting off with a positive reputation.
!998 4.6 F-150 Auto 2wd 153,000 Miles
Starts up like always and runs fine so long as I keep it running with a little gas but let up on the pedal and it stalls out.
IAC ? MAF ?
Old 09-11-2005, 03:54 PM
xtrford xtrford is offline
xtrford is gaining momentum as a positive member of FTE.
Check for a vaccum leak either at your pcv valve elbow or possibly intake manifold, wouldnt hurt to clean the iac with some seafoam deep creep or the maf with some electrical cleaner(very gently I might add).
Old 09-11-2005, 05:00 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Sounds like a sticking IAC to me.
Old 09-11-2005, 05:06 PM
Thanks - Great Site
I cleaned the IAC and it's Fixed.
Many Thanks !!!
What a great site.
Old 09-26-2005, 08:46 AM
Viper26 Viper26 is offline
Viper26 is starting off with a positive reputation.
OK need a little help with the IAC.....
I have the same problem, but could you tell me what the IAC is? I have installed a K&N FIPK kit over this past weekend and now I an experiencing this problem. I'm going to give cleaning it a try once I knwo what it is.....
Old 09-26-2005, 08:51 AM
Fxxer Fxxer is offline
Fxxer is starting off with a positive reputation.
50th ann you may want to just pick up a new IAC because cleaning it is only a temporary fix. I bought one at the dealer, I know the guy, so I only payed $60 but they usually retail around $80.
Old 09-26-2005, 08:54 AM
viper 26 I can't seem to find the link but do a forum search on IAC or Idle Air Control valve and you will find what you are looking for.
Old 09-26-2005, 08:55 AM
OK thanks, but do you know what the IAC is? Or what IAC stands for?
Old 09-26-2005, 08:56 AM
Thanks Fxxer, I will do that.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
