Ok I just got this truck its a f250 its a 1987 with a 460 in it, its also carbed, but anyway the problem its been having is that it will start up and run fine for a couple of times and then it will turn over but wont start if i wait a hour or two and come back to it it will start up fine again but only to do it again later on now ive replaced the coil and the starter selnoid in hopes that that would cure it but it seems that didnt work either what could it be any help would be great.
Sounds like possibly a vapor lock situation. Check the routing of the fuel lines to make sure they aren't resting on anything that gets hot enough to boil the fuel in them when you shut the truck off.
If the engine is turning over but not starting then it's probably not the starter or the solenoid. Sounds like either a vapor lock or a plugged fuel filter.
Welcome to FTE Steve. Please note that I have moved this post to the 1987-1996 F-series forum. Like the two users before me, this sounds like a classic case of vapor lock. Hope you find the information you are looking for.
