292 engine swap ?
Old 09-10-2005, 05:04 PM
kssouth's Avatar
kssouth
kssouth is offline
292 engine swap ?
i got my hands on a 64 f100 with a 292 y block .the guy i got it from said it threw a rod and that a peice of the block at the oil pan was chipped in the process .my question is this ,if i swap engines what engines will bolt in with out a lot of changes .
Old 09-10-2005, 05:32 PM
46yblock's Avatar
46yblock
46yblock is offline
Any 312, 292, or 272 would go in as a direct replacement. 239 from 1955 or 56 would also work, but I expect that would be too small for you. Donar trucks would be 1955 to 1964. Donar cars 1955 to 1962. You can go to [url]www.ford-y-block.com for reference of block castings.
Old 09-10-2005, 05:47 PM
kssouth's Avatar
kssouth
kssouth is offline
are these engines hard to find?
Old 09-11-2005, 01:56 AM
46yblock's Avatar
46yblock
46yblock is offline
They may be hard to find relative to more recent motors. e-bay, old junk yards, backyards and barnyards are all possibliities. You are posting on the Y-block forum, so know that most of us here are Y-block enthusiasts.
If you find a Y-block that doesnt need to be rebuilt, you will be very lucky. Y rebuilds usually cost more than others. A post on the 61 to 66 forum may help in IDing other motor swaps which are easy on your 64.
Old 09-11-2005, 01:12 PM
kens64's Avatar
kens64
kens64 is offline
Not too hard to do. Just about any old truck catalog has swap kits for all Fords, and SBC. I would keep the Y though
Old 09-11-2005, 08:41 PM
286merc's Avatar
286merc
286merc is offline
You will find that the FE is a bolt in swap as it came out in the 65 truck model but was available in cars since 58 as an option to the Y block.
Old 09-21-2005, 12:15 PM
Spiker's Avatar
Spiker
Spiker is offline
Talking Why swap the engine??
My question to you is: why would you want to swap the engine? Seems like your 292 Y-block is rebuildable. Finding a good second hand Y-block is not easy, at least not for us in Europe. If you have the possibility to rebuild the original Y-block this always is the better option.
If this does not work, you can always purchase an "new" old Y-block at Recon, like we did. The outside is old, the inside is total new!!
Just take a look at our website http://www.fordfront.nl, goto "techniek", click on "Klik hier om naar het fotoverslag déassemblage 292 c.i. Ford V8 Y-block te gaan" and enjoy the pics of the Y-Block. As you can see it is not that hard to take the Y-block apart, building it up is more difficult hahaha. We wish you lot's of wisdom and succes, hopefully everything will turn out good for you rebuilding or swapping your block, because riding your Pick-up gives great pleasure!
Greeting from Holland.
Old 10-20-2005, 06:09 AM
f700's Avatar
f700
f700 is offline
292y
my 2 cents worth find a 292 and put it back in hot it up
Redworks
06-21-2015 08:02 AM
Rockydm
17
02-04-2015 02:18 PM
kssouth
09-16-2005 06:30 AM
killerkjn
12-05-2004 04:52 PM
doublej80304
03-19-2004 08:35 PM
Quick Reply: 292 engine swap ?
