Disc Brakes Too Tight - Ford Truck Enthusiasts Forums
Old 08-10-2002, 11:12 PM
wl_keller wl_keller is offline
wl_keller is starting off with a positive reputation.
I seem to have a problem with the front brakes on my 78 F150. The disc brakes on the front seem to be way too tight. If you jack up a wheel it takes quite a bit of effort to roll a wheel.
I have replaced both front rotors, calipers and brake pads and it doesn't seem to help.
Is it possible that the proportioning valve may be sticking and holding pressure on the front brakes? Is there a check valve or something that I don't know about?
When I first got the truck I noticed that there had been water in the brake system. When I rebuilt the back wheel cylinders they were corroded from water contamination.
Is it possible that the proportioning valve may be corroded too?
Old 08-11-2002, 12:00 AM
Big Bad 1Ton Big Bad 1Ton is offline
Big Bad 1Ton is starting off with a positive reputation.
[updated:LAST EDITED ON 11-Aug-02 AT 01:22 AM (EST)]yes it is possiable but highly unlikely, sounds like the seals in the brake master have swollen. Was there extra effort needed to bleeb the brakes?? Did the pedal return back properly or was it slow to rise? Also take a look at the hoses and make sure they are in good condition, if they are cracked replace them.
Don't quote me on this but i don't think there shold be a check valve in the lines for disk barkes
jeremy
Old 08-11-2002, 03:25 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
could be the master cylinder. An easy way to see is to jack up the front. See how tight the wheel is, then loosen the rear line on the master cyl. until fluid runs out for a second. Tighten it back up and check the wheel again, if it is free, then it is the master cyl. If not, well, I have seen some snug fits with new rotors, pads, and such. Have you drove it since you installed the brakes? Do both sides feel the same?
Old 08-11-2002, 08:32 AM
Ford79's Avatar
Ford79 Ford79 is offline
Ford79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to beholdFord79 is a splendid one to behold
Could it be the wheel bearings being too tight? Just a thought.
Old 08-11-2002, 10:47 AM
Hmmmmm.... I've double checked the wheel bearings, they seem to be OK. I'm not sure about the brake pedal because I had my son pump the pedal when I was bleeding the brakes.
I've driven the truck a couple of hundred miles since I rebuilt the brake system. Some days the truck seems to drive just fine and other days if feels like you are dragging an anchor. That's why I started looking for a brake that was dragging.
Both front wheels seem to have the same resistance.
The rotors haven't seemed to have discolored from excess heat, but there seems to be an excess amount of brake dust.
I'm going to check the master cylinder. That's something I haven't looked at yet.
Thanks guys for all your help. If you have any other ideas let me know. I can't find a check valve in the Haynes manual, but that doesn't mean there isn't one.
Old 08-11-2002, 03:09 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
I am having a similar problem with the left front wheel on a van. The two things I am going to look at when I get the time are:
1- Check the caliper piston for corrosion or swelling. Some calipers use plastic pistons.
2- Check the brake line for a possible collapsed lining. This can make the line act like a one way valve.
Old 08-11-2002, 05:02 PM
rocky2 rocky2 is offline
rocky2 is starting off with a positive reputation.
Open bleeder screw on suspected tight wheel,when you think its tight if there's pressure,keep opening up system back to masterC until you find culprit.
Old 08-11-2002, 09:05 PM
dan15000 dan15000 is offline
dan15000 is starting off with a positive reputation.
I once had a problem with my front brakes dragging and it turned out to be the proportioning valve. There's a pin type thing in there that is supposed to be centered between the front and rear brakes. When I put on a new master cylinder it got shoved to one side. I had to take it apart and recenter the pin then everything worked fine.
Old 08-12-2002, 08:55 AM
73Custom 73Custom is offline
73Custom is starting off with a positive reputation.
[updated:LAST EDITED ON 12-Aug-02 AT 09:56 AM (EST)]I've seen the same symptoms you describe, caused by a vacuum booster that is adjusted too tight. Had to remove the master cyl and adjust the rod shorter. It was keeping pressure on the master cyl.
Might want to loosen the master cyl from booster and see if the wheels spin easier, if so then just adjust the rod from booster to master a little shorter (just a little)...
Just a thought.
Marty
Old 08-12-2002, 03:51 PM
rdlehman rdlehman is offline
rdlehman is starting off with a positive reputation.
Had an old dodge with a dragging front brake, turned out to be a bad flexible hose from the frame to caliper.
Bob L
Old 08-12-2002, 10:09 PM
I eliminated the master cylinder. I just went ahead and replaced it for grins.
I'm beginning to think it's in the proportioning valve. After the truck sat for two days while I rebuilt the steering box, the wheels freed up.
After I drove it to test the steering box, I came back and the wheels were stiff again. I released a bleed valve and the wheel freed up.
I noticed that the wires had been disconnected from the valve I suppose to turn the warning light off.
Like someone said earlier, I'll just keep moving down the line until I find it.
I need to check brake booster as someone suggested also. I replaced it sometime last year because it was leaking. I also need to check the flex lines too.
I have to find it soon, there isn't much left.:P
Old 08-13-2002, 09:15 AM
Old 08-13-2002, 09:48 AM
JimmyK1957 JimmyK1957 is offline
JimmyK1957 is starting off with a positive reputation.
A quick way to see if it is the booster push rod adjusted too long is drive the truck til you get the brake drag. Lift the front wheels of the ground and then back off the master cylinder bolts so it moves forward from the booster. If the wheels now rotate freely the booster push rod is too long and is applying your brakes for you. I've seen some trucks that work fine cold, but when the brake fluid warms up and expands after a few good stops the dragging starts. I think the spec for the push rod length measured from the booster to the rod tip is about 1".
F100 Brake does not move downward when pressed INGJP 1973 - 1979 F-100 & Larger F-Series Trucks 13 01-27-2016 09:35 PM
Brake proportioning valve raven3 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-02-2015 12:07 AM
Master cylinder trouble shooting crazy96863 1973 - 1979 F-100 & Larger F-Series Trucks 18 05-07-2012 11:55 PM
Can the proportioning valve be disassembled and cleaned? JEDWIN 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-22-2012 03:46 PM
Brake Proportioning Valve Hamberger Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 01-25-2007 12:02 PM
Tags
brakes, disk, ford, tight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
