400 Cam Choice - Ford Truck Enthusiasts Forums
400 Cam Choice
Old 09-10-2005, 05:05 PM
todder53's Avatar
todder53 todder53 is offline
todder53 is starting off with a positive reputation.
400 Cam Choice
I'm rebuild a 400 in a '79 F250 i'm looking for a cam that will give me the most lope or rough idle i can get but still be a good for towing? Mods are intake, carb, header, trans with shift kit and matched conveter.
Todd
Old 09-10-2005, 11:49 PM
Bouts21's Avatar
Bouts21 Bouts21 is offline
Bouts21 is starting off with a positive reputation.
I've got the 268H from Crane with the same mods as you but with a 4 speed, use it to tow my travel trailer, 29', weighs around 6500#, pulls it with no problems, has a real lope to the idle too.
Old 09-11-2005, 03:14 PM
beeboy's Avatar
beeboy beeboy is offline
beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.beeboy has a great reputation on FTE.
I use teh comp 265DEH, it has a noticeable lope to it at idle.
Old 10-09-2005, 11:43 PM
johaner78 johaner78 is offline
johaner78 is starting off with a positive reputation.
Beeboy, what other mods do u have on that engine? I installed the 265DEH cam with roller rockers and matched valve springs, 3 angle vavle job on orginal heads. Wondering what other mods I can do on the cheap (ie intake (EGR or not), carb, distrib., headers or not, etc.) How is that engine for torque (pulling power) and fuel consumption? Mine is still on the engine stand waiting to go in a 78 crewcab. I want to hear it run----rur!!!!!
eric
Old 10-10-2005, 12:11 AM
beeboy's Avatar
not too much. its got 1971 heads, so no exhaust bumps. Had them ported a bit more anyway. Have the comp K kit, weiand intake, edelbrock 1406. Stock dizzy. Msd 6A. ARP bolts. High flow water pump. Hedman headers. I wish i had bumped up the comp ratio when I had it done.
Power wise, I think its a bit weak off the line, but tows nicely at highway speeds and on hills. I'm running 3.73 gear ratio with 31" tires.
Fuel...ummm..it sucks, literally. I think I get less than 10 with my boat behind it.
Old 10-10-2005, 12:16 AM
ivanvel's Avatar
ivanvel ivanvel is offline
ivanvel is starting off with a positive reputation.
I had a 400 with the comp 270H.. it gave me the lopey mild rough idle and lots power with similar mods as you have
Old 10-10-2005, 08:04 PM
4wheeling79's Avatar
4wheeling79 4wheeling79 is offline
4wheeling79 is gaining momentum as a positive member of FTE.4wheeling79 is gaining momentum as a positive member of FTE.
the comp 268H will work perfect for you and your mods. it has a lope at idel and will pull good from 1500 to 5000 rpm.
Old 10-10-2005, 11:08 PM
go_racing84 go_racing84 is offline
go_racing84 is gaining momentum as a positive member of FTE.
I've heard the 265 in a 351 and yes, it lopes pretty good at idle. I have a SpeedPro CS1085R which has the duration of the Comp 255deh, but the lift of the 265. I have an Edelbrock Performer intake, 600 cfm carb, and long tube headers. The truck has 4.11 differentials and 35" tires. Off the line, I too think it's a little soft. Once you get going though, hit maybe 1700, it starts pulling like a freight train up to about 4 grand.
C6 Trans Shift Kit Question CTC01 Clutch, Transmission, Differential, Axle & Transfer Case 0 03-08-2015 07:28 PM
77 f250 400 Losing power at highway speeds toddev 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 11-13-2013 11:59 AM
351m/400 How do you tell which? todd79_351 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 11 11-06-2008 10:26 AM
AC compressor shuts off after a while todd230 1999 - 2003 7.3L Power Stroke Diesel 35 07-09-2007 08:02 PM
1974 - Ford 361 "FT" Compression Spec Todd_M_S 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-27-2003 11:49 PM
Tags
265deh, 351, 351m, 400, 400m, cam, cams, camshaft, choice, cleveland, comp, ford, good, idle, lopey, rough
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
