F150 to F250 conversion
Old 08-12-2002, 06:16 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Old 08-13-2002, 03:37 PM
tru4tx's Avatar
tru4tx
tru4tx is offline
Hi - I have a 78 F150 4x4 SuperCab. I would like to convert the rear end to 3/4 ton, and have 3.50 gears in front. Does anyone know what the highest gear ratio is available for 3/4 ton this age? I know I can't go with too much of a difference between front and back and still be able to use 4WD. Thanx for any and all advice, Tru
Old 08-13-2002, 06:19 PM
85351ho's Avatar
85351ho
85351ho is offline
[updated:LAST EDITED ON 13-Aug-02 AT 07:20 PM (EST)]ill bet you have a 354 gear in that dana 44 front, and to answer your question, 3.54, so just find a dana 60 with 3.54's and some front 8 lug hubs, rotors and calipers. then youll have a 3/4 ton drivetrain
ford put 3.54's in the front and 3.50's in alot of their f-150's with a 9 inch and 44 front
Old 08-13-2002, 07:44 PM
Scot's Avatar
Scot
Scot is offline
I have an extra 3.54 ratio Dana 60 8 bolt if you need it. PM me if you are interested.
Old 08-13-2002, 11:21 PM
gray79f250's Avatar
gray79f250
gray79f250 is offline
I beleive the front and rear diffs from a 250 are a direct swap in the supercab. If you can find a matched set junkyard etc. you can go with the 4.10s witch will help with bigger tires or heavy towing also. Im trying to buy a 79 150 sc now and if I get it I plan on swapping the dual 60s out of my 250 when the body is done.
Andy
bigmark
Large Truck
04-13-2016 09:21 PM
MartyB
1999 to 2016 Super Duty
18
07-08-2010 12:17 AM
jlang
07-13-2009 12:12 AM
chris69
17
12-16-2003 10:30 AM
weldman
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-16-2002 12:01 AM
Quick Reply: F150 to F250 conversion
