Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-10-2005, 12:34 AM
GotLift's Avatar
GotLift is starting off with a positive reputation.
Did the 6637 mod. Have a question.
So I picked a perfect day to do the mod. My wife and I went to the movies and came out to a torrential downpoor. We hit tons of water puddles on the way home and the truck seemed to be bogged down when going up hills. I punched it up a hill and it sounded like the turbo was sneezing on the shifts.
Grrrrrrrrrrrrrrrr...pshhhhhh....Grrrrrrrrrrrrrrrrr rrrrrrrrr...pshhhhhh
It sounded cool, but I was wondering if it was because of the dense wet air, or if the filter was soaking wet and it was having a hard time breathing. It was raining too damn hard to check the filter when I got home. Thanks
__________________
2000 Ford F-250
7.3L PSD
Crew Cab
Lariet
White/Tan
Leather
Automatic
305/70R16
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-10-2005, 01:03 AM
RubberDuck's Avatar
Death Row Inmate #1
RubberDuck has a very good reputation on FTE.RubberDuck has a very good reputation on FTE.RubberDuck has a very good reputation on FTE.
Gotlift,
Brother I'm certain it was one of two things. One, the infamous turbo stall on the 99 and up strokes. Or two, the wastegate opening beween shifts. If you were really standing on it and the wastegate is hooked up, It will open at a certain pressure. Most likely it was the waste gate. But I would be willing to bet that your filter was dry. Damp at worst case senario. I've had my tymar for a long time and seen an azz load of rain and bad weather and It stays vitually dry. One thing I wanted to remind you of so you don't get dissapointed. Over here the altitude is about 700 feet, I think Alb. is like 5500 ft. I remember driving my Ranger between here and there and noticing a conciderable difference. True it won't be as noticable in the strokes, but present none the less. So if it seemed "more peppy" in Houston, that's why. Don't worry about the filter, as long as you installed it right, it's fine. Rest easy, just look forward to your next mods. Hope that helps.
P.S. If it is the turbo surge and you can't live with it.....two words...wicked wheel. Eat some green chilli for me brother, I miss it bad. I'm out!
RubberDuck
RubberDuck
__________________
RubberDuck
1995 F350 Crew Cab 4x4 dually
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
DP Tuner 2 pos. w/ custom switch
Hot Pedal
Gear Vendors OD
Good bye No.3 I'll miss you.
RIP #17
  #3 (permalink)
Old 09-10-2005, 01:10 AM
GotLift's Avatar
Green Chile... mmmmmmmmmmmmmm
I'm not dissappointed in the performance of the truck at all. I installed the filter mod because the stock filter housing was filthy on the back side of the filter. I've had the truck for a week today and that is the first time I have heard the turbo do that and the only two things that were different were the air filter and the rain. It makes sense that the wastegate was the culprit, but I don't know why this is the first time it has happened.
__________________
2000 Ford F-250
7.3L PSD
Crew Cab
Lariet
White/Tan
Leather
Automatic
305/70R16
  #4 (permalink)
Old 09-10-2005, 01:22 AM
RubberDuck's Avatar
Death Row Inmate #1
Open element filter, your gonna hear everything. And since you did something new to it, your on super what the hell was that alert. It's normal. So what else do you plan to do to it in the near future?
RubberDuck
__________________
RubberDuck
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
Hot Pedal
Gear Vendors OD
RIP #17
  #5 (permalink)
Old 09-10-2005, 01:27 AM
warrens250 is starting off with a positive reputation.
What you are hearing is normal turbo sound that you couldn't hear before because the filter was buried in the box. Nothing to do with the rain; try it on a dry day.
Warren
__________________
02 PSD, F250, 4X4, Auto, Jody Tipton's chip with 40 tow and 80 Econ modes, Kwik NAPA Filter mod, 4" Turboback exhaust, TC lock switch.
  #6 (permalink)
cookie88's Avatar
cookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to behold
So that was the first time you punched it after the 6637 was installed? Get used to the noise. You said it yourself..."I've had the truck for a week today and that is the first time I have heard the turbo", and you are absolutely correct. That's the sound the turbo makes when you pull the plug out of the intake (stock filter). For the first few days you are going to be hearing all kinds of turbo noises that you didn't know were there.
Oh, and the wastegate is intergral to the exhaust housing of the turbo. There is absolutely no way you can hear it operating.
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, 5" stacks, IDM140....and more little mods than I can remember.
79 Bronco- 7.3 IDI diesel project truck - AWM
  #7 (permalink)
Old 09-10-2005, 01:31 AM
GotLift's Avatar
Amen to that "super what the hell was that alert"!
I don't have any immediate plans for mods. I put $11K down on the truck so my budget is wiped out for a while and right now I'm mostly concerned with fuel prices.
__________________
2000 Ford F-250
7.3L PSD
Crew Cab
Lariet
White/Tan
Leather
Automatic
305/70R16
  #8 (permalink)
Old 09-10-2005, 01:34 AM
RubberDuck's Avatar
Death Row Inmate #1
Why That's a damn lie Cookie!!! Just kidding, your right. The turbo unloading, air coming out of something dang it! YOU KNOW WHAT I MEAN!!!!! LMAO!!! There's an explanation for it, I just can't remember it at this point. But it's not the wastegate. Cookie, lay it down brother, tell him what I mean please sir.
RubberDuck
__________________
RubberDuck
DIY Stage 2's
T.E. SD HPOP
Tymar HPX
FPR 70psi
RSB Diesel 140v IDM
Tymar Intake
3"DP to 5" stacks
Hot Pedal
Gear Vendors OD
RIP #17
  #9 (permalink)
Old 09-10-2005, 08:45 AM
RedStroker6's Avatar
RedStroker6 is starting off with a positive reputation.
Quote:
hehe......what a great way to put it...sometimes even if you hear one noise, you go on alert....i know i still do sometimes, and i ain't done a dern thing to my truck other than put expensive fuel into it. hey, 2.69 at Flying J last night. while we're on the subject of hearing things, is it common to hear the clutch plate in the ZF? sometimes i can hear it ( at least thats what i think it is...somethin in the tranny). it just sounds like something in the tranny is spinning up.... usually i only hear it in the low end when theres not a lot of noise pouring out of the stacks.SOUNDS normal, but i wanna make sure....i'm out, got a steel shoot comeptition in an hour and half....
__________________
Adam
95 f250 PSD ZF5. Twin 5" stacks, 5.6K, 6637, Kenwood Deck, 2 Kicker CVR 10's, Audiobahn amp, AutoMeter Pyro. ugly truck but my gal loves it
  #10 (permalink)
Old 09-10-2005, 09:06 AM
Kwikkordead's Avatar
Daddy what's a sparkplug?
Kwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud ofKwikkordead has much to be proud of
Redstroker6, your clutch should operate silently. Are you talking about the gravelly sound at idle when you are rolling along in first gear?
__________________
Dan
Our greatest priviledge is to enjoy God's Presence
  #11 (permalink)
Old 09-10-2005, 01:48 PM
yep. that would be the one. i also hear a slight noise some other time....but i can't describe it cause its been a while since i heard it. but its a spinning noise. i'm used to the gravelly 1st noise....i dunno if the other noise is the clutch, or what. i had it rebuilt with new syncros, new clutch assembly and such about 14 months ago....
__________________
Adam
  #12 (permalink)
Old 09-10-2005, 02:08 PM
strokin_it7.3's Avatar
Overfueled User
strokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to beholdstrokin_it7.3 is a splendid one to behold
are you talking about the sound when you are pushing the stick into first from second, the clutch is grabbing the transmission's gears and spooling them up rapidly to sync with the engine RPM?
__________________
02 F-350 with lotsa bling, some you see, some you don't.
  #13 (permalink)
Old 09-10-2005, 02:18 PM
no...not that one. i'm familier with that one. don't use 1st too much....
__________________
Adam
  #14 (permalink)
Old 09-10-2005, 03:43 PM
Overfueled User
i was implying any downshift, 5-4 4-3 3-2 2-1. usually at slower speeds you can hear it- if you are coming to a stop light and have to change from 4-2, you can hear it "better"
__________________
  #15 (permalink)
Old 09-10-2005, 04:10 PM
cookie88's Avatar
Quote:
Should have started a new thread for this question, it's a little off topic for an air filter thread, but anyways....
It's not uncommon for these clutches to chatter a little as the disc's wear and the springs loosen up a bit, but I think you are probably hearng your dual mass flywheel rattling occasionally.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
