I've read posts on how to hook up the high idle. Last night I went to complete the task, but had no luck. I easily found the wires and ran a jumper between the upfitter #4 switch and the solid orange in the pto bundle. Had power but no luck with the high idle. Any ideas?
Thanks in advance for ideas.
No expert here, but I just hooked mine up a few days ago and it worked fine for me. I also have an '06. But I used the BCP wire. Maybe try again using that wire??? Also, check your brake light bulbs.
Thanks for the replys. I did set the parking brake and have doubled checked that all break lights work properly and tried the purple/light green stripe and also the orange wires to switch #4. I tried again tonight, still no luck. I'm fairly good at following directions--especially these ones so I think there must be a different problem. I'll dig deeper this weekend.
