460 mpg question - Ford Truck Enthusiasts Forums
460 mpg question
Old 09-08-2005, 07:28 PM
jimbo beam's Avatar
jimbo beam jimbo beam is offline
jimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to beholdjimbo beam is a splendid one to behold
460 mpg question
i have the chance to get a 1989 f350 its a 4x4, auto tranny, im not sure what rearend gear is in it though. my question is what kind of mileage do you guys get out of yours.
Old 09-08-2005, 07:37 PM
Uglyhat Uglyhat is offline
Uglyhat is starting off with a positive reputation.
I picked up a 91 2wd sc dually just before gas went from expensive to ridiculous - got 12 to 13 with my first tank - it's bone stock, and needs a tuneup methinks
Old 09-09-2005, 07:29 AM
c_rossman c_rossman is offline
c_rossman is starting off with a positive reputation.
My 93 F250 with Dana 60 up front, 3.55 gears,ZF 5speed,35 inch tires, I can get 15mpg on the highway easy. But mix driving I get about 12mpg's. At 55mph I am only turning 1500 RPM, Foot is just resting on the throttle. Winter rolls around soon and mileage suffers alot. Last winter I only averaged about 10-11mpg, Mornings were cold -25 degrees below. I only have a 11 mile trip to work so the engine doesnt get up to temp for the first 6 miles or so. I dont let it warm up at all.
Old 09-09-2005, 08:22 AM
turbocoupe5.0 turbocoupe5.0 is offline
turbocoupe5.0 is starting off with a positive reputation.
87 460 4bbl F250 4x4 33" x 12.5" BFG AT tires 4.10 gears ZF 5 speed 240,000 miles
I got 10MPG around town & 11 MPG highway
I'm rebuilding the motor with a mild (bigger than stock) cam, headers, and Performer intake. I'm hoping to pick up 1 or 2 MPG. We will see.
Also, removing the tailgate has added about 1 MPG to what I listed above (highway). 1 MPG may not sound like much, but on a 10 MPG truck, that's 10%!
Old 09-09-2005, 06:34 PM
ivanribic ivanribic is offline
ivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud of
I was getting 8-10 before the mods, with 33" tires, 3.54 gears and an auto tranny. Now I'm at 4mpg but that's what happens when you pump up the engine, have 200 pounds spinning per corner and drive like an idiot.
Old 09-09-2005, 09:10 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Quote:
This is scary, an HONEST man.
Old 09-10-2005, 02:24 AM
You go Ivan !!!
Old 09-10-2005, 10:57 PM
Zebich Zebich is offline
Zebich is starting off with a positive reputation.
I have a 97 f250/w 460 and 4.10 gears 4X4. When I first bought it I got about
6mpg towing a 27FT TT. I have added headers,3" exhaust,straight thru muffler,
hot coil,MSD ignition and 8.5 plug wires Have modified the air intake system, I now
get on average 9MPG towing the trailer. The MSD 6A ignition module gained me about
1 MPG. Plan on completely revamping the air intake system by removing the stock
Ford ducting and installing more direct ducting. I noticed when I took a trial run without the ducts connected to the intake manifold, Had noticeable increase in power.
Old 09-12-2005, 09:40 PM
clong clong is offline
clong is starting off with a positive reputation.
91 F250 4x4 with 460 and 33 inch tires, best Higway mileage was 8.8 mpg and when playing around and spinning tires I get 5.
My 79 F150 2 wheel drive with 460 averaged 16 all the time. I really miss that truck.
Old 09-17-2005, 10:55 PM
87 F-250HD 4x4 87 F-250HD 4x4 is offline
87 F-250HD 4x4 is starting off with a positive reputation.
87 F-250HD 460, 4x4, 4.10's, C6, bone stock, towing i get 9, highway i get 9 city i get 9, foot in it foot out, I GET 9. my truck scares and confooses me WAAAAAAAY too much. I suspect a tuneup would help, but, well, i cant come up with a good excuse at the moment, but i'll figure one out sometime.
Old 09-19-2005, 11:11 PM
Gene K Gene K is offline
Gene K is starting off with a positive reputation.
1995 F-350 Reg Cab 4x4 5spd 4.10 33" Mud Terrain
8.8-9.50 mpg (Town + Bass Boat)
9.50-11.0 mpg (Town - Empty)
14.0-15.50 mpg (Bass Boat @ 65 mph)
16.0-17.0 mpg (Empty @ 70 mph)
Thats with a real light foot.
Old 09-23-2005, 11:08 AM
ffemt32ffd ffemt32ffd is offline
ffemt32ffd is starting off with a positive reputation.
Not to be a Jack@$$, but if you want good milage buy a hybrid, if you want a truck with gobs of horsepower by the 460... lol
Old 09-23-2005, 11:44 AM
turbo2256 turbo2256 is offline
turbo2256 is starting off with a positive reputation.
Quote:
Will you garuntee that hybred will tow my 12000 lb or more trailer....lol
Old 09-23-2005, 09:03 PM
Nope, I'll guarantee it won't... but if you're towing a 12,000+ lb trailer I wouldn't be worried about good mileage because you aren't going to get any... I'd be more concerned with good brakes... lol
Old 10-04-2005, 12:23 AM
Heath67 Heath67 is offline
Heath67 is starting off with a positive reputation.
My mileage.................
My mileage is right where Gene K is. What never ceases to amaze me about these trucks is our ability to crawl up the side of a mountain at .5 m.p.h., carry insane loads in the back of them, fly down the highway at 70+ (sometimes WAY plus), and do it day in and day out without many issues. My truck is at 310,000 K (I think thats somewhere around 200,000 U.S.). Yep, I wish I had better fuel economy, but it pulls anything I hook on to, is a daily driver, has been up and down various mountains hauling stone, logs, etc., and is frequently called upon to make a quick run on the highway out to my cabin. Other than the expected cost of oil changes, tires, and brakes, my only unexpected expense was a broken clutch linkage last winter- a $100.00 new parts fix. There is no better feeling than that of a truck that will start when you need it and will do as you ask of it (within reason). I'm often tempted to go out and buy a new one, but there are just enough horror stories of newer trucks out there that prompt me to take mine out and give it a fill-up, an oil change, and a drive into the car wash.
ZF5 swap question for a 79 f250 4x4 apachetech 1973 - 1979 F-100 & Larger F-Series Trucks 12 10-03-2015 10:52 AM
Trailer brake system question WorkhorseF250 1999 to 2016 Super Duty 3 01-04-2015 10:30 AM
Just got my 64 f350 have a lot of questions 69dually 1961 - 1966 F-100 & Larger F-Series Trucks 9 10-08-2014 02:27 PM
What years are best? saggys Escape & Escape Hybrid 4 12-22-2010 10:43 PM
Steering Questions stefanpd@sbcglobal Offroad & 4x4 9 07-25-2003 10:14 PM
Tags
1989, 1992, 1996, 350, 460, dually, f250, ford, get, jayco, kind, mileage, mpg, s650, zf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
