292 Harmonic Balancer
Old 09-07-2005, 10:13 PM
Monte Doenz's Avatar
Monte Doenz
Monte Doenz is offline
Gentlemen,
Should 45 year old harmonic balancer's be changed out or not a problem to worry about on a 1960 292??
Are they known to come apart unexpected and cause damage to other components in the engine compartment??
Thanks for your help
Monte
Old 09-08-2005, 12:16 PM
Homespun91's Avatar
Homespun91
Homespun91 is offline
Monte,
There's no quick answer to your question, unfortunately. I know of many engines running older dampers that have lasted with no problems. I do know of some cases where there has been a problem. As a rule, they do not come apart; rather, the outer ring slips and makes it very difficult to set the timing. (Obviously at this point they aren't serving their purpose as a vibration damper anymore either.) In certain early Chevy small blocks where the dampers aren't retained by a bolt, they tend to come off, & can cause damage on occasion, usually minor.
The few times I have seen/know of dampers "exploding" were for one of three reasons: 1) being revved beyond their design limit 2) being installed with a big hammer instead of the right method, & cracking from the blows 3) damage caused by a cracked crankshaft (hard to tell sometimes which came first, the damage to the crank or the damper)
If the damper is already off the engine, here's what I would do. Clean it, visually inspect it for cracks in the ring & hub, look at the material between the two for signs of splitting, "slipping out" between the hub & ring, or deterioration; check the keyway for proper size; & check the hub bore & crank for signs of galling. If everything looks OK, it likely is. You can ask a machine shop to Magnaflux the damper for cracks, if you want to go the extra mile.
Lastly, I'd verify that the damper mark is still really at TDC, & if it is, call it good.
If it's still on the engine & running fine, with no vibration issues, I woudn't worry about it.
Mike
Old 09-08-2005, 10:01 PM
Monte Doenz
Mike,
Thanks for your great write-up. I think I am good shape.
Buddy of mine has a ~1970 Chevy 1/2 ton pick-up with a 6 cylinder and his let go in the engine compartment with only putting a dent into the wheel well. I have replaced just about everything with this 1960 F-100 4x4 and it made me wonder if I should change out mine before something catastrophic goes on under the hood.
Thanks again!
Monte
Old 09-08-2005, 10:41 PM
Homespun91's Avatar
Homespun91
Monte,
I forgot to mention that various places can rebuild your damper if needed. A lot of the T-bird vendors can arrange to have it done (due to the 'Bird Y-block damper scarcity)- but it ain't cheap. I don't know offhand if the garden variety damper is still available new from anybody like NAPA, or the Effie vendors. ATI makes a performance version of a Y damper, but it's close to $400, & overkill for anything but racing.
Straight sixes tend to eat dampers due to their inherent crank imbalance & the torsional effects of the longer crank. They don't normally fall apart though, just slip. I'm glad his damper didn't cause too much damage.
A good friend of mine was badly burned from a damper exploding, cutting fuel lines, which sprayed alcohol on the headers (pulling tractor), which then ignited & sprayed down the back of his firesuit. He had just climbed off the tractor & pulled his helmet & firesock off- tractor was idling... cost him about two weeks in the hospital, multiple grafts, & a $20,000 engine which proceeded to finish wrecking itself (along with engine #2 warping a blower rotor) while we were trying to get the fire inside his suit smothered. I'm kind of particular about dampers now.
1964FORDTUF
10-11-2014 08:37 PM
IDI guy
15
07-07-2013 09:09 PM
64F-100
04-02-2009 09:24 AM
moneypit56
05-15-2007 09:46 AM
GLASSPACK
07-03-2005 03:26 PM
Quick Reply: 292 Harmonic Balancer
