High Idle when clutch is pressed
Old 09-07-2005, 04:50 PM
Viper1837's Avatar
Viper1837
Viper1837 is offline
I have a 93 f150 with the 302 and 4 speed. When driving or justed park the idle takes along time to come down to 700 rpm if it does at all. Sometimes to get it to go back to 700 rpm i have to tap the throttle several times. When driving and I press the clutch the rpms never drop until it goes into gear. Any solutions as to what could be the problem. Thanks in advance.
Dean
Old 09-07-2005, 06:18 PM
johnsonswamp's Avatar
johnsonswamp
johnsonswamp is offline
Air leak on the intake side maybe? Check your return spring. The throttle cable could have a slight stick to it. Just check all moving parts to do with the throttle, if you find nothing, then its time to see if you have a leak somewhere.
Codymiller
10-08-2018 05:26 PM
chesster51
27
08-09-2016 10:24 PM
The Krustinator
06-19-2015 10:44 PM
Crazy2
20
12-23-2011 11:08 PM
Diesel_Brad
1983 - 2012 Ranger & B-Series
25
03-12-2010 07:42 AM
Quick Reply: High Idle when clutch is pressed
