High Idle when clutch is pressed - Ford Truck Enthusiasts Forums
Old 09-07-2005, 05:50 PM
Viper1837's Avatar
Viper1837 Viper1837 is offline
Viper1837 is starting off with a positive reputation.
I have a 93 f150 with the 302 and 4 speed. When driving or justed park the idle takes along time to come down to 700 rpm if it does at all. Sometimes to get it to go back to 700 rpm i have to tap the throttle several times. When driving and I press the clutch the rpms never drop until it goes into gear. Any solutions as to what could be the problem. Thanks in advance.
Dean
Old 09-07-2005, 07:18 PM
johnsonswamp's Avatar
johnsonswamp johnsonswamp is offline
johnsonswamp is starting off with a positive reputation.
Air leak on the intake side maybe? Check your return spring. The throttle cable could have a slight stick to it. Just check all moving parts to do with the throttle, if you find nothing, then its time to see if you have a leak somewhere.
Idle question chesster51 1987 - 1996 F150 & Larger F-Series Trucks 27 08-09-2016 11:24 PM
Strange Idle issue The Krustinator 1999 - 2003 7.3L Power Stroke Diesel 11 06-19-2015 11:44 PM
1996 460 idle from 700 to 900 and back to 700 Codymiller 1987 - 1996 F150 & Larger F-Series Trucks 1 04-02-2015 06:24 PM
Idle RPM's Crazy2 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 12-24-2011 12:08 AM
High idle Diesel_Brad Ranger & B-Series 25 03-12-2010 08:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
