Rattling in the Back - Ford Truck Enthusiasts Forums
Old 09-07-2005, 12:55 PM
Vandiyan Vandiyan is offline
Vandiyan is starting off with a positive reputation.
I am having a slight rattling in my 1999 F-150 when I am stopped and in drive. The only time the rattling happens is when I turn the stearing wheel to the left and to the right. I figured the sound would come from underneath the front but it comes from the back under the bed. Anyone have any idea on what this might be. I just had a lot of work done underneath on the bed of the truck (a little over 1500 worth) so I am thinking it may have something to do with that. I can maybe try and see if I can get the work sheet that they gave me when the work was done so I can post the details and maybe that might help you experts.
I looked at the work order from back in February and they did a huge overhaul on the rear diff. Looks like a lot of work was also done on the axles as well. Thought this might help a bit.
Old 09-07-2005, 05:22 PM
A_G's Avatar
A_G A_G is offline
A_G is starting off with a positive reputation.
someone might have left a old socket up in there...
Old 09-07-2005, 07:23 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
Check the lug nuts and under the truck for any loose cables or lines? If it's kind of a grinding sound, might be the u-joints.
Old 09-07-2005, 11:22 PM
It is not a grinding sound. Ill check for some loose bolts or something. I was hoping it might be something simple like that. Thanks for the replys.
Old 09-11-2005, 06:11 PM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
May sound weird, but one time I had a 1999 acura and I heard a terrible sound coming from under the passenger floorboard, well a long story short, it ended up being a dumb rubber ball rolling around in the side pocket of the door that I missed because it was black and the door panel was black! Hopefully for you it is something dumb like that!
Old 09-11-2005, 08:31 PM
DieselR6 DieselR6 is offline
DieselR6 is starting off with a positive reputation.
You know...I had a rattle sound that was riving me nuts also...it was coming from the back...but mine was when i hit a bump...had nothing to do with turning...but for everyone out there....it turned out to be the little metal locks that the rear leaf springs have at the ends...one came loose and started making a hell of a noise.
Old 09-15-2005, 11:41 AM
murph1's Avatar
murph1 murph1 is offline
murph1 is starting off with a positive reputation.
more than likely a converter sheild that has come loose or the welds have broken,or tranny lines bumping each other..or on the motor itself..mine did that after dealer changed out bad converters..e/brake cables..hitch insert or the pin that holds it..or a small rock /socket stuck someplace where it should not be...good luck..
Mystery Rattle in crankshaft area CazicT Escape & Escape Hybrid 5 06-28-2014 08:38 PM
Rattling sound??? excoelis 2009 - 2014 F150 12 08-06-2013 06:46 PM
annoying 06 Supercrew door piller rattle crewcabbey 2004 - 2008 F150 0 06-05-2010 08:43 PM
Rattle coming from floorboard TRICKCLOTHING 1999 - 2003 7.3L Power Stroke Diesel 8 09-03-2009 03:48 PM
Engine Rattle rickster51 Ranger & B-Series 17 06-02-2007 09:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
