57 F 100
Old 09-06-2005, 04:32 PM
Jack Davis's Avatar
Jack Davis
Jack Davis is offline
57 F 100
I am looking for the serial # on a 57 F 100 to confirm the # on the title. the factory plate is missing and I'm hoping somebody knows the location on the frame. Thanks Jack
Old 09-06-2005, 06:40 PM
WillyB's Avatar
WillyB
WillyB is offline
On mt 59 the vin number was stamped twice on the right frame rail. Once under th cab near the front cab mount, and again forward of the cab mount.
The one forward of the cab mount could be read just by raising the hood once the rust and dirt was cleaned off. I woud use a wire brush in the area untill I did see the number.
Old 09-06-2005, 06:41 PM
57_ford's Avatar
57_ford
57_ford is offline
Found mine on the top of the frame on the passanger side between the fire wall and the core support.
Old 09-06-2005, 08:22 PM
klatt_89's Avatar
klatt_89
klatt_89 is offline
On my 57 F-250, it's on the passanger side frame rail behind the front axle The inspector said that the book said that on a 57 F-100, that it was in front of the front axle on the passenger side fram rail and on the drivers side frame in front of the firewall.
