Progress report, questions
Worked all weekend on the truck, got the fenders roughly mounted, then put the hood on. In trying to close the hood, the weld broke that held the hood sheet metal to the hood support where the hinge attaches. Also scratched the cowl paint. Took the hood back off, repaired it and am ready to reattach. I've tried to push down on the upper hinge bar where the hood attaches and it won't move, looks like it is interconnected to the lower hinge bar and they move as a team. How do I exercise this part to make sure it doesn't cause more problems?
Also, how is the vent window held into its frame? Can't find any rubber for that ???
-Scott
'53 F100 (probably to be named Elvis, cause the overspray from the Crystal Blue Metallic paint made my sneakers into blue suede shoes...)
-Scott
-Scott
-Scott
Scott -
Sorry I can't help with the hood stuff. Mine isn't stock.
As to the vent window, you need a Shop Manual. It has all the info on installation/removal and a great set of instructions with sequencing. The rubber seals are available from a lot of different suppliers. (One source: John's F-Fun Hundreds, p/n 21448B $60/pr. 1-714-563-F100).
