O2 Sensors, How many and where?
Originally Posted by focusyn
Sorry, CEL is Check Engine Light. Tranny shifts fine and is going into OD and locking up torque converter.
I was thinking that new tranny parts might have something to do with it, but I am pretty sure it's the oxygen sensor or something to do with emissions.
one would thing that the Aero engineers would have put the O2 sensors on the side of the pipe or a least 45d down instead of directly on the top.
Not all Aero drivers are crazy like me and drive thru 18" of snow heading for that perfect snow camping spot or winter photo.
Haven't torn anything off the bottom yet but have come close, few large boulder dings and comalong pulls out of holes.
Originally Posted by VanGo
My '93 4.0 has one by the cat.
If you change it, use patience. Hit it with Liquid Wrench (LW) or equivalent. It's too cramped to get my O2 sensor tool on it so I used a wrench and tapped it with a hammer. It took a few cycles of tapping and LW.
BTW, the Bosch part is a 22mm nut size.
Originally Posted by 96_4wdr
wrap a rag around it soaked with penetrating oil overnight, then do the 6 point box end wrench and hammer tapping, factory doesn't bother with anti seize, time is money and they will never see it again.
I couldn't get the box end wrench on the sensor, the wiring connector wouldn't fit through it. I was tempted to clip the wire, but I'm gald I didn't, as it turned out, I had to reinstall the sensor so I could run to the store and get the right one.
I'm headed off to Atlanta for the weekend, and will be able to evaluate mpg with the new O2 sensors.
#28
#29
Replaced O2 sensor... twice. First one was apparently defective, second one seems to have the van back to its old self again.
Didn't have to use much force either. Of course, I soaked it overnight in Corrosion X (www.corrosionx.com). The stuff works better then my old favorite, PB Blaster or WD40. It's more expensive, but you have to use less of it. The Rejex paint protectant they sell works pretty good too.
Corrosion X helped remove the original shocks from their mounts with little fighting or rounding of the nuts.
#30
Originally Posted by xuzme720
guess I need a bigger hammer, either that or my aero is just more determined. seems like it never just gives up. think we should get some sort of recognition through ASE for just getting near an aero with tools in hand. lol
