Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-05-2005, 05:43 AM
Motorhead351's Avatar
Motorhead351 is starting off with a positive reputation.
Arrow *video* Col. Flashman's I-6
Click on the link below, once there, scroll down 1/4 of the page, you will see Click to watch:,you now have two options:
*click on the thumbnail box or link under Click to watch:
*or, right click on the thumbnail box or link and select Save target as (ideal for dial-up users)
http://www.supermotors.org/vehicles/registry/showmedia.php?id=240902
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-05-2005, 08:19 AM
DT 466Man's Avatar
DT 466Man is gaining momentum as a positive member of FTE.
Sweet...
Sounds nothing like mine though, but it's still sweet. Probally only cause he has mufflers and i don't.
Col. good job. That is an awsome truck with an awsome motor.
How's she drive?
DT
__________________
Sophomore at APSU majoring in Pre-Vet, minoring in Ag Buis.
1985 FORD F150/250 IH 6.9 IDI,Stage1 injectors, new IP, rebuilt motor,NP-435 4spd, NP208, 4.10ls at both ends. rear springs out of Cab/Chassie F350, Still 3/4 Ton Frnts. 4" lift 131k miles
98 Jeep TJ 3"lift 33's, 5spd. 201k, perfect condition, just got done rebuilding the motor.
  #3 (permalink)
Old 09-05-2005, 09:22 AM
hiball3985 is starting off with a positive reputation.
maybe you should post this on the 48-60 forum also if possible, many there have been following this story
__________________
JIM
1960 F100 Panel
223 3 spd overdrive
1966 F250
390 4 spd
  #4 (permalink)
Old 09-05-2005, 10:31 AM
by the way, thanks for posting that video
__________________
JIM
1960 F100 Panel
223 3 spd overdrive
1966 F250
390 4 spd
  #5 (permalink)
Old 09-05-2005, 11:41 AM
Quote:
Quote:
by the way, thanks for posting that video.
I just placed it in the 48-60 section as well.
No problem at all.
To give an idea of how bad I have the I-6 bug, I spent the entire day, literally, trying to put together a corrupt file, finally Col Flashman resent the files and bam, it worked great. Needless to say, the wife was not happy.
  #6 (permalink)
Old 09-07-2005, 11:11 AM
bchunter's Avatar
bchunter is starting off with a positive reputation.
That sounds awesome. I just got a rig with the 6 in it and would like it to sound better. What system did you use? What mufflers? What size pipe? Thanks for all the help.
  #7 (permalink)
Old 09-07-2005, 06:20 PM
Col Flashman's Avatar
Col Flashman is gaining momentum as a positive member of FTE.Col Flashman is gaining momentum as a positive member of FTE.
300 H.P. @ 4600 rpm & 400 F.P.T. @ 3200 rpm w/ a 10 to 1 C.R.
It idels @ 675 & is smooth as glass, a quarter was placed on top of the Valve Cover & it Did Not move Nor rattle @ least on the Dyno's engine stand anyway.
Ross Pistons 4.060
Hastings Power Flex Rings .060
Federal Mogul Mains .020 Under
Clevite Performance Bearings Std.
Federal Mogul Cam Bearings Std.
Melling Torque Cam
Melling H.V. Oli Pump
Eagle H-beam Rods 6.300 2.100 Rod Journal
Crane Gold Race Roller rockers
ARP Main Stud Kit, Rocker Studs,
Doug Fisher International Damper
Bore 4.060
Power Hone 4.060
Full P&P Intake & Exhaust
Performance valve job
Performance Balance job on Steele Crank w/ in 7 grams
Grind Rod Journals to 2.100
Plumb Intake for Heat via Water Pump
Deck Block to Square
Align hone to Factory specs
Deck block for Zero Deck
Offenhauser C Intake (thinking of going to a D/P)
Holley 1850 600 CFM (thinking of going to a 450cfm)
S.S. Borla 2 into 2 Header
8' of 3" tubes attached to Flowmaster 40's
4 Core Desert Radiator mated w/ the Original Radiator Housing
2 1,200 CPU Electric Fans, on @ 180*, off @ 170* mounted diaginally
MSD 6A Eclectronics Package & Coil
Mid 70's Ford Electronic Ignition (the mallory wouldn't fit?!.)
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica)
My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
  #8 (permalink)
Old 09-07-2005, 06:39 PM
WoomaHodal's Avatar
WoomaHodal is starting off with a positive reputation.
wow.
wow.
and...
wow.
__________________
Black 1981 F100 Flareside - Inline 6 300cid 4.9L with EFI Exhaust Manifolds, Walker Downpipe, Offenhauser Dual Port intake manifold, Holley 390cfm carburetor
Blue/White 1969 F100 - New Project
  #9 (permalink)
Old 09-07-2005, 07:30 PM
bchunter's Avatar
Very impressive. Maybe this is what my truck might grow up to be.
  #10 (permalink)
Old 09-07-2005, 10:47 PM
deisele75's Avatar
deisele75 is starting off with a positive reputation.
how much cash do you have into that engine build?
__________________
1978 F250 Supercab 4x4
33x12.50...For now
4.10 Locker
460/C6
2006 F150 SCrew
305/65 R17, 5.4L/Auto,
Vollant CAI, Magnaflow SIDO,
EDGE, 2 1/2 Leveler, Audio.
Watch me trick Fred
  #11 (permalink)
Old 09-07-2005, 10:52 PM
Total for the build on the engine was $4246.64.
__________________
Cheers
Colonel Flashman
  #12 (permalink)
Old 09-10-2005, 12:48 AM
bchunter's Avatar
That's not bad at all. I was looking at $6000 for a rebuilt stock 7.3 IDI. Just came back from huntin, and the more I drive this truck, the more I like it. Thanks for sharing a great truck with us Col.
  #13 (permalink)
Old 09-10-2005, 01:18 AM
shmoozo is starting off with a positive reputation.
Quote:
Originally Posted by Col Flashman
300 H.P. @ 4600 rpm & 400 F.P.T. @ 3200 rpm w/ a 10 to 1 C.R. ...
Out of curiousity what grade of gasoline does the engine require?
  #14 (permalink)
Old 09-10-2005, 04:09 AM
Premium.
__________________
Cheers
Colonel Flashman
  #15 (permalink)
Old 02-26-2008, 11:30 AM
franko is starting off with a positive reputation.
Um, I love you.
__________________
We’ve become a new nation of indentured servants, signing gigantic 2 year deals with ridiculously high early cancellation fees. All for a ****ty camera phone with Hillary Duff ring tones.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
