adding a tach
Yes, you can add a tach, but this is DIS ignition system (no distributor) so you have to get the tach signal from the engine computer. There's a wire you can tap into (don't remember the color code) but you may still need a module to make it accurate.
Take a look at www.autometer.com for more info. Hope that helps, and welcome to FTE!
thanks
thanks alot and i'm glad to be a member of the best site dedicated to ford trucks! anyway, would it be possible to replace my stock speedo-only-in-dash with another ford OE in-dash, one that comes with the tach? i am asking this because i wanna go for the stock look without a tach mounted on my a-pillar or on my steering column. btw, i have a non-digital tripometer, if that makes a difference.
will this one work?
found this on ebay... will this work? i'm thinking that the shift indicator will just slip right in...
http://cgi.ebay.com/ebaymotors/97-98-F150-EXPEDITION-INSTRUMENT-CLUSTER-CF008_W0QQcmdZViewItemQQcategoryZ33675QQitemZ79977 47334QQrdZ1QQsspagenameZWDVW
if link dont work serach www.ebay.com for
97-98 F150,EXPEDITION INSTRUMENT CLUSTER CF008
first link is what i'm looking at...
i know that this may not be the ideal replacement part, but its a start. i'm gonna search some other sources...
Link didn't work for me. Any cluster from a 97 or 98 with mechanical odometer would work. Mileage is a different story. I have been told you can increase mileage by spinning the wheel, but it will break if you try to decrease the mileage. I didn't try that. I kept my old cluster, and saved a picture of the one I bought off of Ebay. The shift indicator will just clip in. As far as 99 and above models, it is not so easy. Mileage is stored in the PCM, i believe, and there is also a PATS issue. I don't think it is just a plug in replacement like it is for the 97 and 98's.
scottscott
04-22-2010 04:08 PM
taylor0987
05-16-2005 02:39 PM
