Offroad & 4x4
is it possible to twin stick a np 208
Old 09-04-2005, 05:04 PM
fords_forlife's Avatar
fords_forlife
fords_forlife is offline
I've searched through a lot of threads and haven't seen any mentioning twin stick shifters for the 208, can someone point me to a company that has em if there is one.
FORDS_FORLIFE
Old 09-04-2005, 05:51 PM
bremen242's Avatar
bremen242
bremen242 is offline
No. An NP208 is a chain driven case. You can only twin stick gear-driven cases (ie NP205, Dana 20 etc).
Old 09-04-2005, 11:16 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
nope like bremen said only geared cases can be twin sticked. on chain drive cases there is only one shift rail that moves a fork inside the case that in turn moves a sprocket that engages and disengages the 4x4 sprocket. on a geared case there is 2 seperate shift rails and two seperate sprockets to control the 4x4 drive system
hope that made some sort of sense somewhere!
-cutts-
Old 09-05-2005, 04:53 PM
fords_forlife
that makes sense, thanks. So then would a gear driven case be stronger and how hard would it be to swap out the 208 for a 205 and would it be worth it just to have the twin sticks. the truck in question is a '82 F-150 that will eventually recieve a dana 50 TTB and FF dana 60 rear.
FORDS_FORLIFE
Old 09-05-2005, 10:45 PM
fishmanndotcom
gear driven case is always stronger simply due to the fact that the chain can't pop off and wedge itself somewhere it aint supposed to go
yes it would be well worth it as the 205 is 100x stronger than the 208 (trust me, i know from experience ) and also the twinsticks are badass! it's cool to be able to do front wheel burn outs and make your buddies do a double take
word of advice! do NOT mess with the D50ttb. you will be wasting your time! a solid axle D44 is stronger then the D50ttb! that swap is also very easy and is extremely worth it (speaking of the Dxxttb to D60solid axle). and iof you can get a sterling 10.25", 14 bolt, or D70 rear axle as they will hold up WAY better then the D60 rear!
just my opinion
-cutts-
Old 09-06-2005, 01:57 AM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
Its Comin Right for us!
Received 1,431 Likes on 935 Posts
the 50 is an upgrade from a 44 if your running large tire sin my opinion. 30 spline outers and inners, and the larger u joints, not to mention ball joints and wheel bearings
Old 09-06-2005, 10:50 AM
fords_forlife
yes I know that the dana 50 isn't as strong but should work fine for now besides it was given to me by a guy who didn't have the room to store it and has already been gone through and has 4.10 gears I need. the 60 was also cheap initially but after I spent the $120 for clutches and $120 to set up the gears but it is done now and ready to go.
FORDS_FORLIFE
Old 09-06-2005, 05:08 PM
fishmanndotcom
o ok! i didn't know you had everything planned out already! if you need any parts i have a d50 sitting down at the barn i will be scrapping sometime in the near future. PM me if you are interested!
ya the D50 is stronger than the D44ttb but i personally dont think it is stronger than the D44 solid axle mainly due to the inside u-joint. i haven't had much first hand experience with them but in my bronco club there is always someone talking bad about the D50's.
anywho, cool man! glad ya got it together. leats your junk runs
-cutts-
Old 09-07-2005, 06:15 PM
fords_forlife
so how hard would it be hang a 205 in place of the 208. anyone have a good pic or details of a swap.
FORDS_FORLIFE
Old 09-07-2005, 09:36 PM
fishmanndotcom
well the case itself is a direct replacement... menaing it'll bolt up. you will need to rework your crossmembers and your driveshafts will need to be lengthened/shortened, and the shifter hole may need to be cut out a lil but what i did is just heat the shifters and bend the shifters!
no pics but i did this swap almost a year ago in Jan!
-cutts-
bnmccoy
3.0L Powerstroke Diesel
52
06-11-2015 11:07 AM
7.3forlife1227
04-29-2014 06:58 PM
Homelessduck
03-14-2007 03:51 PM
oldhalftons
07-11-2004 06:00 PM
sbishop
04-06-2004 08:34 PM
Quick Reply: is it possible to twin stick a np 208
